Question about Dewalt 18 Volt Compact Drill Kit
Gearbox slipping no drive in any torque - Dewalt 18 Volt Compact Drill Kit
  • 1,384 Answers
It may have a bad gear, first take it apart , you can take pictures this will help when it comes time to assemble . then look here for your parts that you need to fix it ... www.toolpartsdirect.com ..parts take a week or so to get !! if'n i was any help throw me a bone and vote thanks jay
Posted on Jul 28, 2010
My rpm shoot up and no power
On the basis of a 7 word statement with no other info or context , I can offer the following:
1. You are in neutral or park;
2. If manual gearbox , your clutch may be slipping;
3. If automatic gearbox, your torque converter may be slipping.
Jul 23, 2014 | 2003 Pontiac Grand Am
Eliminating prop slap low speed high torque situation
The slip yoke in the back of the gearbox has probably worn out, and or the gearbox mount is damaged. Broken engine mounts can also cause this to occur. The alignment of the Gear box and the Rear axle to the chassis can also cause the slapping of the drive safe under load. If the prop shaft does not have a center support, it is more important to make sure that the shaft and not bent, is manufactured into a straight line and properly balanced, and that all of the that the Uni Joints have not failed.
Jul 12, 2014 | OMC Factory Propellor Shaft Assy Part...
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
Espesific location of turbine speed sensor on transmission 1998 cadilac deville
their is no such thing as a turbine speed sensor ,as in the torque converter ,you measure the speed of this from the RPM of the engine their is no other sensor that iam aware off ,the next sensor is the road speed sensor or mph sensor which would be on the passenger side transmission shaft drive just on top right by the differential .Their is no sensor measuring the gearbox side of the torque converter speed as it will be the same as the RPM but allowing for slip which is why the torque converter is their in the first place and their is a specific graph for this sort of information with variables for vehicle weight /power /gear ratio /load .
Mar 11, 2011 | 1998 Cadillac DeVille
Hie I have got a Subaru Impreza 1998 model Automatic, when driving it skips from gear 1 to 3, giving a sort of a jerking, i think it's a gearbox problem i love my car & would like it fixed if...
Hi and welcome to FixYa!
Looks like that the problem will be on the torque converter. If the torque converter is faulty the gear tends to slip. I strongly suggest that you replace the transmission fluid and torque converter to resolve the problem. Once replaced a smooth ride and shifting will be noticeable.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 26, 2011 | 1997 Subaru Legacy
Location of torque converter
your torque converter is located between the engine and transmission, it slips into the trans on the input shaft which drives the pump and bolts to the rear of the engine onto a flywheel which is bolted onto the rear of the crank.
Jan 21, 2011 | 1991 Jeep Cherokee Limited
1995 Ford Explorer, 4.0, 4x4, near 200k miles. Vehicle shudders at light acceleration at approx. 55mph after deceleration. The symptom is intermittent and is less likely to occur with harder throttle. I...
1995 ,and changing gearboxes ,is it honestly worth it ,this vehicle is 15yrs old and not worth more that 500 euros in its present condition ,their are two of these gas consuming monsters here in a local car dealer and i expect he would pay you to remove them ,anyway if you do change it then i doubt if you need to change the torque converter ,but you will have to remove it with the box so you can locate it in the new one prior to fitting ,their is a dog clutch shape that has to align for the front pump drive .Best advice is to renew the vehicle with a diesel coupled to a manual gearbox
Dec 09, 2010 | Ford Explorer Sport Trac Cars & Trucks
Mk1 VW Polo drops out of gear on over-run
more likely to be a worn baulk ring.do yourself a favour and rebuild the box,its so much easier and will last longer.to test,apply slight hand pressure to gearlever in drive and over run if it slips out......its time for a rebuild....
Jun 15, 2010 | 1986 Volkswagen Golf
I have a 1985 Mercedes 300TD While entering the freeway, the engine started racing as if in neutral while in D. after a full stop all seemed fine until about 12 mph, when again no gear. Drives fine in L...
Dear kev4,
The problem seems to be originating from your gearbox. The gear box has two main components that convert the torque of the engine to the tailshaft; the 'torque converter' and the 'bands' within the gearbox. If at higher rpm the car starts to rev higher and slow down then it would suggest that one of these two components are slipping or not functioning correctly.
To fix this problem you will have to take your car to a gearbox specialist who with either reccomend a replacement gearbox, a overhaul of the orriginal gearbox or if you get lucky a new torque converter. Unfortunately this car be a costly opperation but is quite important in reguards to the life of the vehicle.
Reguards luke.
Feb 12, 2010 | 1999 Mercedes-Benz E-Class
Transmission- no sign of slipping, automatic transmission. Fluid good and full. Transmission quit while travelling down the road. No reverse, no drive. Transmission functioned good until that point.
this is caused by your torque converter inside your gearbox being faulty when this part goes wrong it is very rare that they can be fixed so if the worst may happen you will need a new torque converter however this can be an expensive part ask your local garage for a quote
Aug 13, 2008 | 1989 Nissan Maxima
Dewalt 18 Volt Compact Drill Kit Logo
111 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
