Question about Black & Decker SpaceMaker ODC325 Coffee Maker
Water is not pumping from water reservoir to make coffee
    New Friend:
  • 47 Answers
Try this solution. It should fix your problem.
Posted on Jun 11, 2011
My unit says prime and no outflow.
"Prime" usually indicates the pump is sucking air. Sometimes the valve in the bottom of the water reservoir gets stiff or gunked up; if you turn off the B60, remove the water container and drip some water into the water intake until it's full, turn the unit back on, replace the water reservoir and that little amount of extra water should be enough to allow the pump to work properly.
Apr 24, 2016 | Keurig B60 Coffee Maker
My Keurig coffee maker will not pump water into the chamber, I have tried the fixit suggestions but to no aavail. Machine was used less than 6 months.
Take the K-cup insert out.
Insert a small paperclip and carefully insert upward into exit needle, swirl to dislodge debris (clog could be preventing H2O uptake).
Do this for all three of the holes in the exit needle.
Add distilled white vinegar to reservoir.
Run "Brew" without a KCup to see if this clears the reservoir uptake and exit needle.
Fill reservoir with water and run to clear vinegar from system.
Mar 13, 2014 | Keurig B60 Coffee Maker
Water pump makes a lot of noise when pulling water from tank
You may need to descale the coffee machine... Use white vinegar and put into reservoir and run until reservoir is as empty as it will get. Fill with water and run to clear....I do this twice to make sure the vinegar odor is gone.
Oct 10, 2013 | Keurig Platinum B70 Coffee Maker
Water will not pump through machine to make cup of coffee. Descale indicator light has never come on,but can not even descale because when handle is pushed down,no water is pumped through.
Lift up the water reservoir and drop it back into place. There is a magnet that has to be in the right position and putting the reservoir back into place causes it to go back where it should be. This method has worked for me
Oct 04, 2013 | Keurig Platinum B70 Coffee Maker
Keurig B70 automatically pumps water when turned on
Purge and Descale unit to reset the system to original state.
Jun 26, 2012 | Keurig Platinum B70 Coffee Maker
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
Pump is running but no water is being drawn from the reservoir
I haven't had this happen where nothing is being dispensed, but if you have small portions being dispensed or the pump is noisy, I tried 2 things that work for me:
1) remove the reservoir and over your kitchen sink, with water still inside the reservoir, use your pinky finger, small chopstick, etc, and gently push the inlet valve a few times from underneath to let water out. After about 2-3 months, our unit seems to stick (rubber seal that closes),
2) put some vinegar into the reservoir with some water and run the unit about 3-4 times on largest cup setting. Clean out the reservoir, replenish with fresh water and run the unit another 6 times. Believe me, you need to flush the vinegar out well, otherwise any residue in your coffee will not only taste bad, it will curdle your milk/cream. I've had my B70 Platinum for 15 months making about 8 cups everyday, Hope this helps..:D
Jan 08, 2010 | Keurig B60 Coffee Maker
B60.Coffee maker was working fine untill yesterday, now brews 1 cup and pump starts but does not pump and machine shuts off. Help me. Bill Cobb
Hi Bill, sounds like similar a problem I had with my Keurig Coffee maker. Your pump may be plugged with mineral deposit build-up from your water. Do you use regular tap water or filter it in any manner?
Have you ever cleaned the insides with vinegar? Empty your reservoir of water, and pour a bottle of white vinegar into the reservoir. Run the maker through several cycles to ensure the vinegar has worked its way throughout the ‘guts’ of your maker, and then let it sit for 2-4 hours.
Empty any remaining vinegar from the reservoir and then cycle at least two full reservoirs of water through to flush the vinegar out. When you stop smelling vinegar in your coffee cup, you’ll know when there’s no vinegar left inside.
You should probably clean you Keurig once a year, or more depending on how heavily you use it.
SWMBO tells me you’ll find similar instructions above in the Owners Manual or you can check out this link: http://www.ehow.com/how_4927372_clean-keurig-coffee-machine.html
Good Luck, I hope this helps! – Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Dec 09, 2009 | Keurig B60 Coffee Maker
My coffee maker suddenly stopped pumping water. no water flow and no sound of water pumping.
the hose inside the reservoir popped out of place. You can reach it by hand to put it back.
May 13, 2009 | KitchenAid KCM400 Coffee Maker
Gaggia cffee machine will not pump water through th coffee
my gaggia coffee machine, will not pump water trough the coffee. I see the water going back in the reservoir. I used the cleaner cafiza, but no help. Please help.
Thank you
Jul 06, 2008 | Gaggia Classic Brushed Stainless Steel...
Black & Decker SpaceMaker ODC325 Coffee Maker Logo
93 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
jason
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
