Question about HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001
I have a HP Pavilion dv6000, I was told by best buy that it wasn't turning on because of the hard drive needed to be replaced which I doubt because it should still turn on but go to BIOS. ANyway, I took it apart and where the circle battery thing is on the motherboard it has a burned spot. I already know that i have to replace the motherboard now but is there anything else I need to worry about since everything connects to the motherboard?
  • psylenc Jul 28, 2010
    But the burn spot burns even more when i plug in the charger.
  • 10,319 Answers
No. clean the burnt spot and replace the battery
Posted on Jul 28, 2010
Tip
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
18385245_1.jpg?w=200 1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250 2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
on Jan 21, 2010 | Computers & Internet
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
Hp pavilion dv6000 battery not chargering
First try to reset the battery to see if it helps any by doing the following: Turn off all power saver settings on your laptop, disconnect the laptop for the ac adapter. Then use your laptop and run the battery down ignoring any low battery messages until it dies. Then let it fully charge for a night without turning it on, and see if it has saved any charge. If it still hasn't saved any charge, it seems like the only option is that its a dead battery and needs to be replaced. Best of luck!
Jul 14, 2010 | HP Pavilion dv6000z Notebook
Laptop DVD
Try cleaning the DVD drive with compressed air, if it still does not work try cleaning the drive with a DVD disk cleaner. if it still does not work and the software for the DVD drive has been confirmed as operational then the drive is dead and needs replacement.
Jul 07, 2009 | HP Laptop Keyboard for HP Pavilion DV6000...
My hp pavilion dv 9000 does not start.
Hard drives are cheap. Find out what type of drive this supports (i.e. ATA or SATA), and buy a new drive. They're quite easy to replace, too. You'll just need a recovery CD to re-install your OS (operating system) after you put in your new drive.
Jan 03, 2009 | HP Pavilion dv9000z Notebook
HP pavilion dv6000 laptop
Were you offered any chance to back up settings and files?
Upgrading Win is normally pretty safe with more than one opportunity to save the previous version & setup and/or a restore opportunity.
I doubt your files have been overwritten; they are probably still present unless you were offered and opted for, a reformat of your HD.
There is probably a D: partition on your drive; it may be hidden, but gain access to it to see if you have a recent folder that refers to the previous installation.
Aug 27, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000 dv6100 dv6200 dv6300 dv6400 Motherboard - 434722-001 Logo
100 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
