Question about Dryers
How do I oil ther drum? - Dryers
  • 171 Answers
No need to oil drum.  no metal to metal contact anywhere.
Posted on Jul 28, 2010
Busted oil pan now can wont start tryed cranking to start
Did you replace the oil pan? many new cars have an oil level sensor and will not start if they read low oil so as to prevent the motor from seizing from too much heat and friction/wear.
Apr 01, 2014 | 2006 Chevrolet Cobalt
Drum error
Hi, the drum is the part where you insert the new cartridge toner, some times when you replace the toner need to clean the small filament in the drum unit, is very simple, ther is a blue part, slide 2 o 3 times and return to his original position marked with a arrow, maybe this solve your problem,9436fabb-a042-4f75-962b-c59ad843e6bb.jpg
Sep 17, 2013 | Brother HL 2140 Laser Printer
How do you get the rear brake drum off a 2005 corolla
you will need to back off the brake adjuster through the slot in the backing plate, ther are some threaded holes in the brake drum, find some bolts and screw into these to help push the brake drum off
Apr 16, 2010 | 2005 Toyota Corolla
Drum Replacement procedure.
Hello sir; Ther have one srew to release from image unit, pull out image unit, in front of the unit you can find one srew tight the drum shaft, remove this screw pull out the drum shaft the drum unit and developer unit separat meanwhile remove the drum
Jan 30, 2010 | Toshiba 1370 Black and White Copier
My whirlpool dryer makes a loud noise and shakes while operating
you have bad a bad roller.first you nead to remove the lint filter.next you nead to remove the two screw's at lint filter opening.now grage top on both side's and pull forward and up.ther are two 5/16# screw's one obnthe left and one on the right.pull frount panal forward and u[p to remove frount panal.position panal on the right side.reach under drum and release the drum belt.now you can take the drum belt and lift it up and remove the drum.now you see the right roller.ther is a plactic holder that hold's the roller on.remove the holder and remove the roller.replace the roller and the holder.now reinstall everthing.
Nov 17, 2009 | Dryers
How to remove rear brake drums 1988 toyota pickup
ther are two little hole in the drum that are threaded put two bolts that match those holes and thread them in untill the drums pop off
Oct 21, 2009 | 1988 Toyota Pickup
Oil in spark plug hole
Check the spark plug is may not be tight enough, don't over tighten it as you will damage the head.
Replace the plug as it may be missing its oil ring.
Hope this is of some help.
Ed
Apr 18, 2009 | 2005 Gilera Runner VX 125
BLACK LINE DOWN DOW PAPER
If this problem is on a laser printer there is only one thing causing the issue.
More than likely there is a permanent scratch in the surface of the image drum that goes all the way around the cylinder.
To verify this simply remove the toner cartridge from the unit and turn it over. You should see a small plastic shutter mechanism which is covering the photosensitive drum. Carefully open the cover without touching the drum surface with your fingers as the oils on your skin will damage the drum surface further. If you see a mark in the drum surface, that is your problem and the toner/drum unit will need to be replaced. This most likely was caused by something that was accidentally introduced into the imaging area of the unit. Before putting a new toner/drum cartridge into your printer verify that there are no obstructions like a paperclip or even smaller a staple as this will get caught in the new unit and cause the same problem. This problem is not covered by manufacture warranty and therefore you will need to bit the bullet and buy a new one.
Hope this helps solve your problem. I used to work as a Systems Engineer for Kyocera-Mita a printer and copier manufacturer so I have seen this issue hundreds of times over the past 20 years.
Cheers,
Keith
Oct 21, 2008 | Office Equipment & Supplies
Asko w6761 front loader
you can remove the grey drum paddle to get access to the inner drum stick a small screwdriver in the middle hole of the paddle and pull towards you other wise you would be better getting an ako tech to do it because ther are three panels to remove plus a clamp band.if you havent done one before it can be difficult,also check the pin trap it may have gone in ther(filter bottom left corner)
Oct 10, 2007 | Asko W6761 Front Load Washer
Resetting image drum
U need to go on the program in your computer and from there reset the drum, probably u have one called okidata, ther u have a OP8z monitor.
Jan 15, 2007 | OKIPAGE 8z Led Printer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
