Question about Husqvarna 25HP Hydrostatic 54"Cut Garden Tractor
Drive belt I`ve got a yth20k46 tractor, and someone tried to put a new drive blet on, and brought it to me to fix. I can`t figure the drive belt location, hwo does it run thru the pulleys, as near as I can tell they have the flat pulley in the wrong place
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 12 Answers
Sounds like u think someone has moved a pulley.
If not, u already know that the back of the v-belt, or flat side runs against flat pulley, most of the time just taking up slack.
The belt probably pulls over the top of the pulley with the back side of the belt rolling on it. Your drive and blade pulleys will keep it in line.
Where's the belt tinsion come from? Spring idler or slide adjustment?
Some times it takes some head scratching but u can figure this out.
ballping
Posted on Jul 28, 2010
Husqvarna YTH20K46 lawnmower does not move forward when in drive
Check the drive belt and pulleys. Make sure the belt is tensioned when you release the brake.
Aug 25, 2014 | Husqvarna Garden
Husqvarna yth20k46 tractor sputters when blade is first engaged, then evens out?
When you put a load on the engine the governor opens the throttle plate on the carb further to allow more fuel. Sometimes it can take a second for the engine to catch up when this happens. As long as the tractor runs fine once it catches back up I wouldn't worry about it.
Aug 24, 2012 | Husqvarna Garden
Fitting new drive blet
just loosen the adjuster and when it loose pull-out the loosen belt and replace with the new one and retight the adjuster at exact belt tension
Jul 13, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Just put a brand new B-belt on husqvarna yth20k46 and I've double checked for correct belt routing. Everything is correct and transmission still won't engage.
Has the transmission been put into bypass ( push mode )? there will be a lever from the box to engage/dissengage the unit.If this is ok check the splines on the transmmision pulley they may have stripped.
Jun 17, 2012 | Garden
The drive belt on my husqvarna yth20k46 is off at the pulley above the transmission. How do I get it back on? Do I have to remove the nut at the transmission shaft?
I would remove the nut and pulley. Get belt top of pulley. Start the edge of belt in broove on pully and run it around. You get easyer belt in pulley and install it. May have pull little against spring.
Mar 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Yes I need help on a Husqvarna model #YTH20K46-960450004 this is a 46" riding tractor. I need a drive belt and deck belt. can someone supply me p/n so I can order plz. thx..Eric
My name is Dane and I am going to help you solve your problem.
Drive belt: 532 13 09-69 Deck Belt: 532 40 51-43
Here's a link to your manuals!!!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=yth20k46&types=O,I
I hope I've helped! Thank you! Dane
Dec 30, 2010 | Husqvarna Garden
Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Jul 16, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna yth20k46 - When turning transmission does not work
I only had my mower 3 months and that problem started. I was told to change the drive belt, It got worse. Now the transmission will only drive the mower for about 15 min and will come to a complete stop. I have to let it sit about 30 min before the drive will work again. No solution yet but I'm looking at replacing the "sealed" drive assy. I do have a very healthy yard of St Augustine which is tough. I can mow a thinner yard a little longer.n
Apr 06, 2010 | Husqvarna Garden
Husqvarna 25HP Hydrostatic 54"Cut Garden Tractor Logo
395 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
