Question about Nespresso Le Cube
My Nespresso ?Le Cube? machine is leaking water heavily. At least ΒΌ of a longo-cup of water leaks into the pod container when I?m making a longo. The most water is coming from a small hole just above the pod container. I tried descaling the unit but this did not help. Also the procedure for removing air out of the system I followed and did not help. The unit is out of its warrantee period and Nespresso asks a fixed fee of about 120Euro?s and can not guarantee a full repair for this price. A new machine cost about 180Euro?s on the web. Does anyone have an idea what the problem could be? Is there a service manual on the web available so that I can try to repair the unit myself? Henri
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Posted on Feb 05, 2011
The water in my Nespresso does not come through the from where the pod is, but fill the drip tray! what is wrong?
I had a coffee machine that was letting out the water instead of making the coffee it turned out the hose that leads the water was disconnected from the source if you can get to the hose you may find the problem good luck
Jan 03, 2015 | Nespresso Coffee Makers & Espresso...
Nespresso magimix
Check the relay on circuit board
Jul 20, 2014 | Nespresso Le Cube
Espresso and Longo buttons flash simultaneously and continuously
Try holding both buttons down while you turn the machine on until they stop flashing - usually about 5 seconds. This will reset the machine to its factory settings. Hope this helps.
Apr 06, 2012 | Nespresso Le Cube
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
My Delonghi N95 Nespresso machine is leaking water
on a N95 fill the water container and take it off the machine if it leaks its just the red seal on the botton but if thats not it put the water container back on full of water,let it sit for a bit,it wil leak out the front or side it will be the dark grey seal in the base were the outlet of the water container sits in, I found this with vmine anyway,it was hard to see it leaking but was a pain in the but!! i will talk to Delonghi or pull the seal out and match one the same
Ant
Feb 12, 2011 | DeLonghi Nespresso EN660 Espresso Machine
Le Cube: Water does not flow after tank in Le cube ran dry....
Open the lever (the one on top of where you put the pod, and keep pressing it backwards until water comes...
May 18, 2010 | Nespresso Le Cube
The small and large cup buttons are alternatly
I had the same problem and was told it needed to be repaired by Nespresso and the cost would be 115 euros.
Jan 07, 2010 | Nespresso Le Cube C185 Espresso Machine &...
May 16, 2009 | Nespresso D290 Espresso Machine
No water coming out but water tank is full
CAN YOU OPEN STEAM VALVE DURING BREWING??
DOES WATER LEAK FROM STEAM PIPE DURING BREWING??
Apr 01, 2009 | Nespresso Le Cube
Nespresso Le Cube Logo
189 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
