Question about HP PSC 1610 All-In-One InkJet Printer
HP 1610 printer photo paper jams
Hi I have an HP 1610 printer that fails to print on photo paper (jams), normal paper still prints fine.
The paper feeds in up to the rollers, sometimes a jam is reported, others it begins printing without feeding the paper making a mess inside the printer.
I've tried 2 different brands of photo paper, photos print ok on plain paper. the printer settings are set of photo paper.
  • jim_cordwell Jul 30, 2010
    Solution 1 does not appear to have looked at the problem stated, just advises how to install the printer.
    The actual problem is that he printer is very slightly damaging the edge of the paper as it first begins to feed it, this causes it to get stuck at the rollers when trying to print. The damage is minor but is visible and can be felt by running a finger along the leading edge that went into the printer.
    I've not been able to find what exactly causes the damage, there is no debris etc. in the way.
    The problem can be worked around by lifting the lid when the print starts, slightly lifting the roller where the damage is and closing the lid. Printing resumes and completes successfully.
    Scholar:
  • 103 Answers
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Posted on Jul 28, 2010
Photo printing errors
This is not the fault of printer. Choose those type of photo paper, whose thickness is equal to executive bond paper. This type of printer do not catch the thick photo quality paper
Apr 09, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper jams with photo paper only hp1610 all in one. will print photo on regular paper any size.machine also makes a "grinding rotating" noise
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
May 08, 2009 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 1610 printer ... error message alternates between carriage jam and out of paper
i cleaned the clear file strip behind the carriage by rubbing it between my fingers and my printer started working again. before that i had paper jam and carriage jam and it wouldn't do any printing or copying.
Nov 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Samsung ML-1610 Does not print after a paper jam
after checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Oct 17, 2008 | Samsung ML 1610 Laser Printer
Paper jam
Hi Marybarron,
Please visit the below mentioned link, if you want to know:
How to fix the Paper Jam problem
Also, you will find the opening instructions on that page itself.
Thank You
Oct 16, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP 1610 printer
It occurred to me when I was reading your post that photo paper has printing and non-printing sides. If the paper is loaded upside down, it's printing on the non-print side, which would result in what you're seeing. It's just a hunch, but you might want to consider it.
HP.com has a web page that will walk you through the process of checking on this and other potential problems.
Checking image quality problems
Hope this helps. Good luck.
Oct 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer jam
hve u tried removing the paper jam from a proper place.hp has provided a door behind the printer to clear paper jam.open that door n check out 4 any paper part left out in it.wish u success
May 31, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP 1610 - Skipping Lines when printing w/carriage return
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC 1610 All-In-One InkJet Printer Logo
234 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
