Question about Brother P-Touch PT-1830 Label Printer
Printing stuck in mirror image how do I remove it? I have gone into Print option and tried to turn offf MIRROR IMAGE without any joy.
Beni S-P
  • 1006 Answers
SOURCE: mirror image when I print
Use original cd for driver and repair the driver and if the problem will not be fixed i will be here ;)
Posted on Oct 19, 2007
SOURCE: reverse printing
Have you found a solution for this problem??   I have the same problem; happens sporadically but once it happens there's no fix.  With the particular page I am printing I can't get it to correct itself. I thought at first it was associated with Classic apps but that wasn't consistent.  I just printed from Safari on a wireless iBook and this page is also reversed.  Extremely frustrating!!!!!
Thanks.
Posted on Jan 12, 2008
SOURCE: Mirror images only
hopefully you have fixed this problem by now----if not, go to control panel bt clicking start then settings or could be start then control panel. WHAT YOU ARE LOOKING FOR IS THE PRINTERS AND FAXES FOLDER. once you have found that, right click on the HP Officejet Pro L7500 Series (or whatever your printer name is) and choose printing preferences. go to the advance tab. look for mirror image and click on it you will be given a small drop down to toggle it from on to off----choose off and the click on apply and then OK.
Posted on Aug 20, 2008
yooperbud
  • 8637 Answers
SOURCE: Printing on a MAC returns mirror image printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
websnail
  • 419 Answers
SOURCE: Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Posted on Feb 13, 2009
HOW DO I DO MIRROR IMAGE PRINTING
go to start, printers and devices, double click on your default printer (the one with the check mark) click on adjust print options, click ok on the popup window, click on the advance tab and there you will see different options for your printing preferences. click on the plus next to printer features, you will see mirror image and it will say off next to it. Click on it and change it to on. click apply, ok and you'll be set! To turn it back off just use the same process but select off under mirror image printing.
hope that helps!
Oct 10, 2010 | ASUS Computers & Internet
Printer prints mirror image only.
check the menu in the printing section. there should be a section that gives you mirror images, dark background white letters etc..
need more info on the model .
Aug 19, 2008 | Office Equipment & Supplies
HP J5780 printer is printing backwards
You may have the Mirror image turned on.
Open a job to print. Select File>Print. When the Print window opens, select Preferences, then click on the Advanced tab.
Look for the Mirror Image option. If it says ON, click on it and change it to OFF. Then click OK.
Mirror Image is mainly for iron on transfers.
Thanks for using Fixya.
Nov 20, 2009 | HP Officejet J5780 All-In-One InkJet...
Prints backwards
You have probably turned on the "Mirror Image" option.
When you go to print and the Print window comes up, select Preferences and then the Advanced tab. Look for the Mirror Image option and Disable it by clicking on the underlined option and change it.
(BTW, the Mirror Image is used to print iron-on images for t-shirts, etc.)
NOTE: If you don't see it on the Advanced tab, look on the Effects tab.
Nov 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Won't shut down, won't finish boot - no functionability
I have had a similar problem since I bought this printer. When I make a copy or scan a document, the printer refuses to print anything else directly from the computer. If I turn offf the printer, I get the "printer is shuttting down" message in the display, however it never shuts down ( I've even left it overnight!) I have to pull the power plug out and wait ~30 seconds and then plug it back in to restore functionality in the print mode. I get some kind of nag screen at start up telling me that I didn't shut it down properly but I have just learned to ignore that. This problem is so consistant that I don't even try to print after making copies without unpluging the main power plug. Another issue you will probably run into is if you install Service Pack 3 on Win XP all your documents will print out in mirror image. HP's lame fix for this is to have you make custom settings in the print manager to remove the mirroring mode from the settings!! I am just about ready to change brands after being a faithful HP customer for over 25 years. They seem to have no interest in fixing known software issues anymore, as their push is to get new devices in the pipeline as soon as possible.
Good Luck
Tony
Oct 04, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP L7580 printer prints mirror image
Turn the mirror image option to on. If it does the same turn it off than uninstlall and reinstall the complete software.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7555
When you select "Print" and get the print window to confirm....select "Preferences". On the Advanced or Effects tab, look for the "Mirror Image" menu item. Turn it Off. If you cannot find it, comment back.
(BTW, the Mirror Image option is normally used to print t-shirt transfers.)
Dec 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Brother P-Touch PT-1830 Label Printer Logo
124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
