How do you scan multiple pages on a brother mfc 9180
  • margaret1983 Apr 27, 2008
    Sorry I didn't explain myself properly. What I want to do is scan multiple pages using the feed system, say maybe 20 pages at a time. Is this possible or do I have to scan the pages one at a time.
    Thank you
    Genius:
  • 1,447 Answers
Using the printer as standalone How do you scan multiple - bb69290.jpge321a17.jpg
Posted on Apr 24, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 24, 2008
    using the computer, when you go to scanner setting, i think i misunderstood you awhile ago. sorry. Here is the correct way.
    try going to this link as well
    http://welcome.solutions.brother.com/BSC...
    page 75
    So you will use the scan to word processor setting then SCANNER settingUSE OR SELECT (photos), then press on the modify setting. But the easiest way to do it is by using the SCANSOFT PAPER PORT for Brother application.. Hope this help. If you have inquiries feel free to reply back. Have a nice day!!
I have a Brother MFC-9180, it has a DR8000 in it. The machine come up on the display saying "Change drum soon" which I have done, the new drum did not come with a page to feed into the drum. I want to...
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
Or Try this:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002800/000037/faq002837_009.html?reg=as&c=au&lang=en&prod=mfc7220_us_as
Oct 20, 2013 | Brother International Brother MFC-9180
Can I connect Brother MFC 9180 to MacBook Pro?
Use a usb cable or connect through a wireless connection if MFC has such a capability.
Jan 21, 2013 | Brother MFC-9180 Printer
The manual that comes with my brother MFC-7840W covers all functions ACCEPT scanning! How do I scan multiple pages into ONE file so I can send a single file to someone. Thank you, Jeff Vanskike
Information on the scanning function can be found here:
http://welcome.solutions.brother.com/bsc/public/as/au/en/faq/faq_list.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
In order to scan a multi-page document into a single file, you must configure the scan to use a file type that supports multi-page documents. For illustrated instructions of how to scan multiple pages into one file instead of each scan being saved as a separate file go to here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002500/000078/faq002578_001.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
Feb 10, 2011 | Brother MFC 7840W Printer
Brother printer mfc 9180 Blobs on page at certain intervals
The blobs are probably dried toner on the drum. The solution is to use a soft piece of cloth and rub the blobs off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the residue has been removed from the drum and it is clean, the blobs should have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
May 20, 2010 | Brother MFC 9180 All-In-One Laser Printer
I have a brother mfc 9180 and the error message keeps coming up replace the drum. I have done this How do I reset it
your new drum should have had a plastic "starter sheet" installed just level with the exit hole. this sheet resets the counter, and should not be removed before fitting the new drum. The sheet will be automatically ejected when you have fitted new drum. If you still have this sheet it can be refitted to the drum, then reinstall the drum. Works for me ! MFC 9180
Jun 05, 2009 | Brother MFC 9180 All-In-One Laser Printer
Sending multiple pages in one email attachment after scanning
well go to scanning setting and change it, you change the setting to be sent one by one, if its connected to network, browse the ip address and go to scan and change the setting, if to usb cable go to the driver setting and change it, and i think from the machine setting itself can let you, so its just setting.
Mar 21, 2009 | Brother MFC-7420 Laser Printer
Brother MFC-465CN How can we scan multiple documents?
Make a stack of the documents you want to scan and load them in the automatic feeder: The page to scan facing upward, and the top of the page inside. Press the Scan button and start (color or black).
If you choose the pdf format, you will have them in a single file.
Hopr it helps.
Feb 18, 2009 | Brother MFC-465CN InkJet Printer
Scanning multiple pages
Use paper port software which is part of brother software suite but under different menu (check out under start - programs - paperport
Feb 05, 2008 | Brother MFC-7820N Laser Printer
Brother MFC 9180 - Wrong operation signal
Press every button on operation panel, I've known this model to get em stuck , please define if input is noticed in display and if mode switch ie fax, copy operates if key isn't stuck.
Jan 30, 2008 | Office Equipment & Supplies
582 people viewed this question
jasbo
jasbo
