Question about Tascam 2488mkii 24 Track Recording Workstation
When iplug usb cord into my computer the computer fings new hardware, says it's ready to use and then says malfuntion then doesn't read the2488mk2 at all
  • Tascam Master
  • 5,603 Answers
The driver software in your computer for this device is NOT properly installed or is missing.
Some of these recorders require additional software in the computer to work propely.
Posted on Jul 28, 2010
LED Light not coming on
Did you get it used or brand new?
M-Audio is notorious for hardware related problems, mainly the USB ports. After awhile the ports wear and fail to hold the tight connection needed to keep the board fully functional. But I've seen the same problem with new boards too because of bad soldering.
If it's new then don't bother wasting time trying to figure it out. Just exchange it and save yourself the headaches. You may even want to look another board. If your partial to M-Audio then the Axiom is much better than the Oxygen. Either way, take advantage of the ability to exchange while you can, cause once that's over M-Audio will give you the finger.
Jun 23, 2017 | M-Audio Oxygen 49 USB Midi Controller
I have a casio privia px-130, and I'm trying to use it as a MIDI on FL Studio, but it won't show up in FL Studio. Is there a driver that I have to download?
Make sure you follow the steps of the procedure below exactly. Connecting incorrectly can make data
send and receive impossible.
1.
Turn off the digital piano and then start up
your computer.
• Do not start up the music software on your computer
yet
3.
Turn on the digital piano.
• If this is the first time yo
u are connecting the digital
piano to your computer, the driver software required
to send and receive data will be installed on your
computer automatically.
4.
Start up your computer's music software.
5.
Configure the music software settings to
select one of the following as the MIDI device.
CASIO USB-MIDI
Apr 19, 2013 | Casio Privia Px-130 Px130 88 Key Digital...
Behringer pmx2000 doesn't turn on
Check the fuse which should be close to the power cord on the back. Check it with an ohms meter or replace with a new one.
Mar 18, 2013 | Music
Which midi cable or USB midi cable should I use for Yamaha DGX 520 model.
It doesn't use a USB to MIDI adapter (such as the UX-16.) It has an onboard MIDI controller and uses a standard USB A-B cable. You just need to install the driver from the CD-ROM or here, and plug it in. You can get the manual from the same page or here. Setup is on page 99.
Oct 20, 2012 | Yamaha DGX520 Portable Keyboard - 88 Keys...
This may sound dumb but I'm very new to this, my A&H ZED10FX mixer I purchased doesn't seem to have its USB output recognised for recording. It says that the computer should be able to...
Check that it is listed in "control panel" "Sounds and devices" as options in the voice, recording, and playback tabs. If not there, you may need a driver for it. There are so many options of software and operating systems for PC's that it is a wonder that any of this works.
May 11, 2011 | Allen & Heath ZED10FX 10 Channel USB Mixer...
Cakewalk v20. lost connection to the device during recording. used it successfully for approx 1 year. nothing new connected at the time of failure. tried new usb cord and different computer. v20 will not...
Check that in the control panel of Windows, "Sounds and devices" your interface is the default device in each of the panels under the tabs such as "Voice" and the others.
May 03, 2011 | Cakewalk VStudio 20 Audio Interface USB
Sir i have purchased Roland gw-8 keyboard in the usb port when i put any flash drive it power is shown but it doen't read and it gives message usb memory not ready sir please solve my problem?
Read pages starting with 49 in your user's manual.
You MUST format the USB flash in the GW-8 before it can be used. Formating in a computer MAY b e inadequate as sometimes the formats have special quirks.
Also pay attention to the MAXIMUM file name length... It is 16 characters MAX !!!!
Feb 16, 2011 | Roland GW8 Keyboard Arranger
I have the Fostex MR-8 mk II without the burner. I'm having trouble as of late at exporting my finished song to a laptop computer. It's worked fine in the past. Could it be my USB cord is bad? The computer...
USB cords are cheap and can often be found even in Thrift stores... try a new one to eliminate that possibility... I will say they RARELY go bad unless they have been abused.
Remember that reading a USB stick by the computer is FAR different than transfering data from the Fostex...
MAKE SURE the driver for the Fostex in your computer is intact...
OFTEN the stupid DLL files that were working get CLOBBERED by new software and suddenly old things that used to work don't anymore... Thank MS for the stupid thing of allowing new software to change DLL's.
Jan 07, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Digitech RP3 Guitar signal processor only lights up.
Check that connectors are seated AND the input and output are correct.
Sometimes1/4 inch plugs are not seated correctely. The power adapter plugs are notorious for not making contact.
Oct 26, 2009 | Music
Tascam 2488mkii 24 Track Recording Workstation Logo
185 people viewed this question
Top Tascam Music Experts
Michial Gueffroy
Computer Links
Lawrence Oravetz
Are you a Tascam Music Expert? Answer questions, earn points and help others
