Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fridge ice machine does not work, Model E522B, have turned machine off and then back on, cleaned ice machine and replaced it in proper place,
    President:
  • 1,099 Answers
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Hope this helpout.....
Posted on Jul 28, 2010
Hi My Fisher & Paykel Model: E522B starts beeping for no reason at random times. When I press the cooler/warmer settings it stops but will start beeping again randomly at a later time. Please...
Hi - I believe the problem is the power module located on the rear of the machine. I have not done work on F&Paykels for a long time.
Whats happenning is the controls is picking up an error with the input power supply, the modules perhaps got an intyermittent issue.
Try this turn your fridge off & back on again - the E522B will start to beep indicating the lose of power which is exactly whats happening to the unit at the moment, to eliminate the beeps you reset with the temp button on the inside.
Jun 14, 2011 | Fisher and Paykel Active Smart E522B...
Fridge not cooling, Freezer is working (upside down fridge/freezer)
We experienced a smilar problem with your Fisher & Paykle fridge/freezer.
The fan that sends cold air to the Fridge section of the appliance didnt appear to be working leaving the Fridge poorly cooled.
I suggest the first step is to turn the fridge off and leave it to totally defrost.
Build up in ice in the freezer section seemed to have an impact on the proper operation of the fan which seems to relie on a thermostat for its operation.
Having defrosted and cleaned the fridge the problem was solved.
The fans have a delay before switching on after the door is closed. Place a magnet over the door sensor switch and wait to see if the fan works.
The problem could be that the unit has iced over itself over a period of time and defrosting it could solve the problem.
Feb 28, 2011 | Fisher and Paykel Active Smart E522B...
The fridge alarm will not stop. The fridge compartment is not cold and the freezer is just freezing. Since the problem started, have the fridge turned off for 3 days. Defrosted the freezer, turned it...
this alarm is activate if the temp. of the fridge rises and because the freezer section is full of ice form thats why affect the circulation of cold air. try to check the defrost timer if yuor unit have or heater if working if dont have defrost timer or heater try to lessen the setting of your themostat to cut of unit after reaching desired temp. or conduct weekly defrost manually.
Feb 12, 2011 | Fisher and Paykel Active Smart E522B...
The fridge compartment stopped working but the freezer was okay. Fridge seems to have come good now but lost alot of food in the process and not sure if fridge will fault again. I removed the shelves from...
They both are controlled by different thermostats and it is possible that the fridge one may have got stuck or malfunctioned preventing start up but on cleaning the vibrations may have put it back in place. If I were you I would check up the fridge thermostat & replace if required.
Nov 29, 2010 | Fisher and Paykel Icon E522B Bottom...
I have a model C370 Fridge and has water accumulating at the bottom of the fridge. When I looked at the drain at the back of the fridge it is all iced up.
Happens.....,syringe it out with clorine bleach to clear out any "growth".then dry out the fridge,try to cover all wet food with cling film, to cut down on condensation.drain should be cleaned monthly.....
Sep 24, 2010 | Fisher and Paykel Active Smart E522B...
Ice maker not working. Water is going to fridge,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
68tj
Dec 15, 2009 | Fisher and Paykel Active Smart E522B...
Our N369B fridge freezer has a large amount of ice clinging to the upper back of the fridge how do we stop this happening?
Your freezer door is not closing properly. if it is not on wheels then make sure the bottom nut that also holds the front wheels or slider in place is tight. Also maybe have the seals replaced and check door alignment on both doors. You will of course have to defrost the freezer.
Oct 27, 2009 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
1,035 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
