Question about Dishwashers
I have a model # gsd2030f01ww with a serial# of ga823350b. The problem is it will go through the cycles but when it goes to the final drain.it doesnt want to drain. What could be the problem?
I have the same model with the same problem.
I took the washer apart to find any obvious issues. The motor is functioning, the impeller is free from debris, the solenoid does engage and open flap to redirect water to the drain hose. I believe it drains part way through the wash but doesn't drain in the cycle just before the dry cycle.
Posted on Dec 05, 2011
Brand new Bravos. Why doesn't it do the final spin?
NO ITS NOT UR DOOR SWITCH IF IT WAS IT WOULDNT SPIN ON ANY CYCLE. I SUSPECT U HAVE A TIMER THAT IS STICKING AND THE POINTS HAVE BURNED OR SEIZED
May 26, 2015 | Maytag Washing Machines
Serial # SD117482G
Most likely the control or timer. What is model #?
Nov 17, 2017 | GE WBSE3120B Top Load Washer
Kenmore laundry center model 92702 burning smell during spin and water doesnt drain
mine does this regular easy job if your desent at diy are you missing socks or wires from bra's as it probably the pump blocked take the pipe of the pump and see if there is any thing stuck in the pump remove it as long as pump not damaged should be fine probably get some loose change as well lol
Aug 17, 2012 | Kenmore 92702
I have a model FWT867GHS0 and serial number XC11512433, when it gets to the final spin cycle there is still water in the machine and it will not perform the final spin.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump may need replaced
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washing machine doesnt stop ever!!
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the laundry center.
Mar 23, 2017 | Whirlpool Washing Machines
New water pump, cleaned trap, checked little vaccuum hose and it wont do final spin. No errors on panel and everything else works fine
If your washer fills to the correct level, agitates through the wash cycle, and then drains, I would check the door safety switch for proper positioning and switching operation. The switch should have minimal resistance (closed circuit) when it is depressed and high resistance (open circuit) when released.
Jul 31, 2009 | Washing Machines
Having issues with my washer Model # LSR7010PQ0. Will not perform final spin cycle. All the water is draining.. basket just wont spin. Tried the spin cycle on one of the other settings and that worked. ...
As the machine goes through the cycle, it should do what is called a neautral drain (drains water without the tub spinning) then a momentary power intreupt allows the gear to slip down and the spin begins. If this is not occouring on one cycle, it is usually a bad timer.
Jun 13, 2008 | Whirlpool Washing Machines
Washer will not Spin during SPIN CYCLES
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. (consult your manual to know where/how filter is cleaned). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 29, 2007 | Washing Machines
Dishwashers Logo
71 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
