Question about Samsung RFG237AABP (226 cu ft) Bottom Freezer French Door Refrigerator
TURNED ON ICE BUTTON, BUT STILL NO ICE, WHY - Samsung RFG237AABP (226 cu ft) Bottom Freezer French Door Refrigerator
    President:
  • 1,099 Answers
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Hope this works .........
Posted on Jul 28, 2010
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Stopped making ice. Display says "ice off." How do I get it start making ice again?
This would suggest that the ice has been manually turned off. Try using the ice selection button to see if it returns to either cubed or crushed ice again and it should start working.
Mar 06, 2015 | Samsung Refrigerators
Ice marker stopped making ice
There is a test button underneath of the motor side of the ice maker. Unplug your refrigerator for 5 minutes then push the test button on the ice maker if it doesn't move you need an ice maker if it does move and you still don't get any water the metal tube that supplies the water to the ice maker is frozen up and blocking water from coming into the mold.
Nov 07, 2013 | Samsung Refrigerators
Every half hour or so it sounds like a power surge...an electrical sound coming from the upper section of my French Door bottom freezer refrigerator. I do not have the water hooked up for ice making...and...
You have a problem with the control board program. If the ice making button is turned off, the ice maker should stop working completely but it sounds like it's wanting to make ice.
Jun 28, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
Ice crusher stuck on crush mode can't swith back to cube
is it push button or do you manually have to turn dial from crush to cube. I have push button and had this problem once before.(LG side by side) I turned off at power (remove cord from wall) and removed ice tray all together. save some ice for testing. Check to see if crush part was clean. Put ice back in container and put back together and turn back on at power point. See if you can have cubed now.
Dec 14, 2009 | Frigidaire FRS3R4EW 33" 22.6 Cu. Ft....
Ice maker stopped working. Turned it off as there's no way I need a bin full off ice. I also don't use a lot of ice. Ice was "getting old" so I dumped it, cleaned the bin, turned the button on and nothing....
The freezer temp needs to be around 0 degrees for that "something" to click to tell it to dump and make more ice. Check the freezer temp and adjust if needed. If a thermometer says it's cold enough you may need that warranty you mentioned.
Jun 25, 2009 | Samsung RB215LASH
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Feb 14, 2008 | Sub-Zero 690 Side by Side Refrigerator
Samsung RFG237AABP (226 cu ft) Bottom Freezer French Door Refrigerator Logo
151 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
