Question about GE (PSS26MSRSS) Side by Side Refrigerator
Our automatic ice dispenser hums but doesn't move ice through to be dispensed
Resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Posted on Aug 28, 2010
Cerfer39
  • 709 Answers
SOURCE: Ice dispenser
Hi Wilday1, Sounds like you have a possible defrost malfunction. In this case the Ice maker motor may have become iced and cannot turn the auger. Tell me if you have frost buildup at the back of the frezer and ice crystals on the auger drive. If you do , then you need to remove the Ice makers motor and allow it to thaw and defrost itself. be sure it is completely dry before putting it back in. I hope this helps.
Posted on Oct 08, 2007
  • 1073 Answers
SOURCE: ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
Posted on May 07, 2008
mikedurland
  • 481 Answers
SOURCE: Ice dispenser in door will not dispense ice
this could be the:
door switch (usually 2 switches, 1 for the light and 1 for the dispenser) auger motor itself the dispenser switch or the plug near the hinge that connects the door the the refrigerator has a bad connection. this connection is hidden under a plastic hinge cap usually.
Posted on Jun 28, 2008
SOURCE: Ice Dispenser does not work.
agree, but add most common problem is tray not installed(inserted ) correctly not seated Above solution is good cause most common reason is ice buildup preventing proper seating So after cleaning make certain it goes all the way in and it should sort of SNAP or click into place AND SHOULD BE LOCKED IN If is pulls right out, then u are n ot getting it in properly You should have to press a button or lever to remove it also check that metal wire arm is DOWN to make ice lastly the corkscrew thing must turn to dispense ice, you should hear it turn and stir the ice If it makes noise(hum and ice noise) then the chute thru the door is just clogged good luck
Posted on Jul 16, 2008
  • 744 Answers
SOURCE: ice dispenser not dispensing ice or water
Check the water filter - it should be at the bottom of the fridge - turn it 1/2 turn to the left. After several months of use (less if you use it a lot) the filter can clog.
Posted on Jun 24, 2009
Ice maker makes ice and dispenses to ice bucket but will not dispense from the door
Check that the motor is connecting to the drive and isn't broken. Also. Check to make sure no frozen chunks are jamming the auger
Oct 07, 2015 | Refrigerators
Whirlpool refrigerator ED5FHEXVSOO is not dispensing ice out of the door
The dispenser is jammed; the motor is humming because it's stuck.
Sep 16, 2014 | Refrigerators
Ice dispenser problem Samsung rf4287hars
Check that you ice maker is on, do you have ice in the bucket?
Check you ice drain is not plugged. Do you hear some humming noise when you push the ice dispenser? This could be a complex problem.
Feb 27, 2013 | Samsung Refrigerators
Ice dispenser will not dispense ice, but it will dispense water
It might not be hooked up right. Or there could be something blocking the ice dispenser.
Nov 28, 2012 | Refrigerators
Ge side by side refrigerator model tfx20jrx ice wont dispense
If the auger will move freely with ice out of the pan then the auger motor may be defective. Sometimes the connection in the door switch is defective. When the door is closed the switch turns the circuit on to the auger and control panel. Because the auger uses more amps that the water dispenser the door switch may be the problem or auger motor is just worn out.
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSS25LGMF WW Will not dispense ICE or Water, lights are on
Hi, I have had a similar situation. In my case the filter needed to be replaced. Otherwise the water solenoid is bad or clogged. And check the water supply valve. Best of luck. , Tim
Feb 13, 2009 | GE GSS25LGM Side by Side Refrigerator
GE side by side not dispensing ice out front
could be frozen auger motor, try turning motor by hand.
May 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Aug 10, 2007 | Frigidaire GLRS264ZA Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
113 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
