Question about Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White
The freezer side quit staying cold today. No
The freezer side quit staying cold today. No problems until today. Refrigerator side is still cold. Model number is ED5STGXKQ00.
  • Whirlpool Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 28, 2010
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
My Hotpoint HSS25IFMD fridge quit cooling on the refrig side. It stays at 55 degrees. The freezer works just fine. Any thoughts?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Dec 27, 2010 | Refrigerators
If the coolant from the freezer compartment leaked, will the refrigerator still work (stay cold)? I know the freezer won't work. thanks.
There is only one coolant circuit for a refrigerator. There is a fan that circulates the cold air from the freezer side and pushes it through the refrigerator side and that's how that gets cold. So if all or some of your refrigerent leaked out then the refrigerator will have to be repaired by a qualified technician if you still want to use it.
Sep 17, 2010 | Haier HNSE05SS Stainless Steel
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator and the freezer is not working properly, the food is thawing in the freezer and the refrigerator is not staying cold. The compessor is running and blowing cool air. It just started...
Possible defrost problem. If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air.Since you've already replaced the motherboard Checkdefrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerator side want stay cold
sonnds like your control board is going out .and possibly your cold control.
Feb 27, 2008 | Refrigerators
Whirlpool 25.3 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - White-on-White Logo
79 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
