When windows update i get a message saying check the data connection settings and ensure the device date and time is correct
  • 415 Answers
Switch off automatic updates you dont need it and just download it manually once every 2 weeks,
should be ok
Posted on Jul 28, 2010
Connection to itunes
Hi Yvonne
Several things you can try...
To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Update on your device's Summary page. To check that you're in range of a Wi-Fi router or base station.
  1. That your date, time, and time zone are correct. Tap Settings > General > Date & Time. Time Zone might list another city in your time zone.
  2. That your iOS software is up to date. To check for updates, tap Settings > General > Software Update. You can also connect your iPhone, iPad, or iPod touch to iTunes and click Check for Updateon your device's Summary page.
  3. To check that you're in range of a Wi-Fi router or base station. If you're using cellular service, make sure that cellular data is turned on from Settings > Cellular. If you're connected to cellular data, larger items might not download. You might need to connect to Wi-Fi to download apps, videos, and podcasts.
  4. That you have an active Internet connection. For help with your connection, check your device's user guide.
  5. To see if other devices, like portable computers, can connect to the Wi-Fi network and access the Internet.
  6. To reset your Wi-Fi router by turning it off and then on again.
Jul 07, 2016 | Apple iPhone Cell Phones
Cannot unblock iphone 5
Fix the issue on your iPhone, iPad, or iPod touch If you can't connect to the iTunes Store on your iPhone, iPad, or iPod touch, make sure:
If there's still an issue, learn what to do if your device won't connect to a Wi-Fi network.
Jul 07, 2016 | Apple iPhone 5
Cant up date m/s security essentials or delete
Step1 Ensure that the date and time are set correctly on your PC
Open Microsoft Security Essentials.
If the error message that you received contains the code 0x80072f8f, the problem is most likely caused by an incorrect date or time setting on your PC.
To reset your PC's date or time setting, follow the steps in Fix broken desktop shortcuts and common system maintenance tasks.
Step 2
There are other things that you can do however the most easy way is to install updates manually
Manually install the virus and spyware definition updates
If you're running a 32-bit Windows operating system, download the latest updates manually at http://go.microsoft.com/fwlink/?LinkID=87342
If you're running a 64-bit Windows operating system, download the latest updates manually at
http://go.microsoft.com/fwlink/LinkID=87341.
Click Run. The latest updates are manually installed on your PC. http://go.microsoft.com/fwlink/?LinkID=87342 http://go.microsoft.com/fwlink/LinkID=87341
Apr 08, 2016 | Microsoft Windows 7 Ultimate. Windows 7...
Cant update m/s security essential
Step 2
Apr 08, 2016 | Microsoft Windows XP Home Edition
Google play not downlaoding apps
If you're having trouble loading Google Play Store or issues on downloading apps and games,
try the troubleshooting steps below.
These steps can also help with the following error messages:
? No connection.
? Error retrieving information from server. [RPC:S-7:AEC-0].
? "App Name" could not be downloaded due to an error. (927)
? Connection timed out.
Step 1: Please ensure that you have a valid Internet connection and then, restart your device.
Step 2: Please ensure that the date and time is correct as to the current date and time.
Step 3: Go into the Application Manager.
Tap on Google Play Store and then tap on Clear Data and Clear Cache.
After you have actioned this please do the same for the Download Manager app.
Step 4: If the issue persists, go back into the Application Manager and tap on Google Play Store. Then tap on Uninstall Updates.
It's kinda lengthy process I can't explain here you just need to call on 1888-588-7141/ 1855-925-7088(toll free)
Dec 26, 2013 | Irulu 7" 4gb Mid Google Android 2.3...
Windows 7 refused to update. Windows 7 refuses to
  1. Do one of the following:
    • Connect a camera to your computer by using the camera's USB cable, and then turn on the camera.
    • Connect a portable device that contains pictures or videos to your computer by using the device's USB cable, and then turn on the device.
    • Insert a removable flash memory card, such as a Secure Digital (SD) or CompactFlash memory card into a memory card reader.
    • Connect a scanner to your computer by using a USB cable, and then turn on the scanner.
    • Insert a data CD or DVD that contains pictures or videos into your CD/DVD drive.
  2. In the AutoPlay dialog box that appears, click Import pictures and videos using Windows.
  3. To change the settings that are used when importing pictures and videos, click Import settings in the Import Pictures and Videos dialog box.
  4. Change one or more settings in the Import Settings dialog box, and then click OK.
  5. Click OK to restart Import Pictures and Videos. Type a tag in the Tag these pictures (optional) box, and then clickImport to import your pictures and videos using the new settings.
    For updates make sure that the time and date are correct, if it doesn't match what time it actually is , it wont update, and make sure your OS has been activated
Aug 29, 2013 | Dell Dimension 4700 PC Desktop
The system clock will not stay set, when I turn off laptop the clock stops and calendar stops . I reset it every time I turn it back on so I receive all up to date updates . Windows updates are set to ...
You need to set the correct date and time in your system BIOS. To access that you need to press the correct key when the computer is first booted (usually DEL or F10/F2/F11).
Most computers will have a message stating press xx Key to enter setup or etc.
If this problem persists even after setting the correct time in your BIOS, your laptop needs a new CMOS battery. I recommend having a professional do this.
May 09, 2011 | Acer Aspire 6920-6422 Notebook
I put in a address like 3269 143 st Surrey BC and a message comes up that the system has to up date data !!!
I am glad to HELP YOU!
I'd suggest you to make a FIRMWARE/SOFTWARE upgrade from the manufacturer's website and to try also to get update(s) for the map(s) that you have installed on your device. I'd say that's why it says "system has to update data"...
My best regards!
useful WINDOWS TIPS!
May 03, 2011 | GPS
I can't login to my Yahoo Messenger app
update your device date/time (option-->date/time-->push BB-->update time
Apr 26, 2009 | RIM BlackBerry Bold 9000 Smartphone
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
