Question about Frigidaire ATF6000ES Front Load Washer
Error code e20 model # gltf2940ee0 - Frigidaire ATF6000ES Front Load Washer
  • 4,323 Answers
Hi
Error code e20 means a clogged drain pump. This might have happenned due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump
Please post back for any further assistance.
Daniel
Posted on Jul 28, 2010
  • frigidthorax
    frigidthorax Jan 23, 2012
    $3 in quarters, some other coins, a broken pen, a bra pad? & some hairy gross out of the filter in front of the pump. back to normal now. thanks alot mate.
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
What do I need to do when my front loader is giving me E20 code
Hey Kim, thank you for your post!
From what you have described your Frigidaire washer is displaying an error code of E20. I am not showing that as a valid error code and I would recommend performing a reset on your washer. You can reset your washer by disconnecting power from it for at least ten minutes. If you continue to experience issues with that error code please respond back and additionally provide me with your model number. You can locate your serial tag (which lists your model number) on the door frame of the washer. Once I have that information I would be able to further assist you. I look forward to helping you further. -Matt
Dec 12, 2015 | Frigidaire Washing Machines
E20 errorcode
Sorry but with no Make we can no assist .try Google Make/model/error code
Sep 08, 2015 | Dryers
Gltf2940es3
good day,
no idea for the E20 error coz all brand have diff error code?
call the service center what the exactly the E20 error?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Washing Machines
Frigidaire front load washer (ATF6000SF1) error E20
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Nov 29, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
E20 message want spin
2. Failed pump
Apr 29, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire ATF6000ES Front Load Washer Logo
353 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
