Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
In the refrigerator section on the shelves I have trouble with things freezing
    President:
  • 1,099 Answers
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Also note that
As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control,do check on that before to purchase the control.
Good luck and hope this helpout.....
Posted on Jul 28, 2010
Freezing milk and water bottles on top shelve
Defective temperature sensor in the fridge section.
Aug 30, 2016 | Frigidaire Refrigerators
Why would food in the refrigerator side freeze?
probably your Damper unit! In the fridge section is a hit and miss type vent using a motor to open and close via PCB temp sensor!
Oct 07, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our Whirlpool GI5FSAXVY refrigerator is freezing items. The temp control has been set to 38 degrees forever. It appears that things on the lower shelves are freezing more than things on the upper...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
Our freezer will freeze water but not food. top shelf frosts over and the other shelves stay clean. food in freezer all defrosted
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have a frigidaire freezer that will freeze water not food of any kind. the top shelf frosts over the other shelves stay clean. we lost the food in there it all defrosted.
heatman101
Sep 04, 2010 | Microwave Ovens
De icing the freezer in a Samsung SW 2630WW
Take all of the shelves out of the freezer side. Take to Philips screws for backing and 4 philips screws from vent cover just above cover. unplug, Use a hair blow dryer and melt it. Put it back together and there you go. Whole operation from start to finish is about 15 minutes.
May 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Nov 12, 2008 | Refrigerators
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water inside the refrigerator
check for a door gasket problem on one of the doors if it is not sealeing all the way you will get moisture in the fresh foor section and additional forst in the freezer
Jun 10, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
