My mum has a zanussi aquacycle 1400, its approx 6 yrs old and has recently started beeping during a cycle. When it starts beeping the cycle pauses and has to be re-set by pressing the pause/start button. I've also noticed that by slamming the m/c drawer with decent amount of force resolves the beeping. Also condtioner segmnt of drawer not emptying, not sure if this is related or not. Anybody any ideas? Thanks in advance, Iain
  • iainmccall Jul 28, 2010
    Cheers for quick reply, hopefully this will do the trick!
  • 11,896 Answers
The drawer switch is likely faulty. You can test it by removing the wires from the door/drawer switch and place an ohmmeter probe on each side and test the switch. Chances are that it's bad.
Posted on Jul 28, 2010
    so to get to the wire's i'm assuming we go in through the front panel. Remove drawer and unscrew from there yeah?
  • Nate Stansfield
    Nate Stansfield Jul 28, 2010
    I think that will do er
Zanussi 1200 aquacycle fx1265w
Either it not getting water, or the motor brushes are worn out.
Sam
Jun 21, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi aquacycle 1200
Turn the machine to the off position. Unplug it and then plug it back in. Now try to restart the cycle. If this does not help find a local washer and dryer repair shop
Jan 24, 2014 | Washing Machines
I have a Zanussi zwf1621s washing machine which is approx 6 yrs old. When spinning today it made a strange noise so i turned the machine off. When I went to restart the machine all the lights came on but...
it really depends on the sound it made, if it was a rumble or a screech it could be the motor, or grinding it could be the bearing or something is in the drum, if it was on a drain cycle it could be the pump or something in the pump blocking/catching on the fins in the pump ( hair can affect the pump). coins can sometimes get to the drum housing and cause damage, ie catch the heating element, this can make the washer not start as the washer has a earthing sensor on the element resistance. hope this helps.
Nov 06, 2017 | Zanussi ZWF1420W Front Load Washer
Zanussi fle1416w aquacycle 1400 xc , on some cycles it does not take in any water into the drum although water goes into the draw, clothes are totally dry at the end. Some times it keeps pausing and...
Check drain hose has not dropped down. that the height of the waste pipe is at least 50 cm high and the waste hose has not been pushed a long way down the stand pipe. all these things can cause the machine to syphon out all the water it has taken in. it more **** to happen on delicate programs with higher water level the beeping would happen after 5mins. comment back if this not the case
Jul 31, 2010 | Zanussi FLE1416W Front Load Washer
Lost instructions
Go to ; www.serviceforce.co.uk
Then click on service center locator, and follow the instructions.
You should be able to find the information you require.
Please rate my fixya solution.
Thankyou.
Jan 30, 2009 | Zanussi F1245W Front Load Washer
Zanussi electrolux aquacycle 1400 xc 6 fx1465 w
i have a problem with my zanussi aquacycle 1400 xtra capacity. some times it works ans some times not like there is a problem with the power the alternater? should i change this part? please help as my wife is driving me crazy.
Mar 20, 2007 | Zanussi F1245W Front Load Washer
assuming you had correct value fuse, fuse blowing may have been caused by a machine fault.after power outage, cycle should resume.
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
