Question about Cadence TXA 1000D High Power Mono Amplifier Car Audio Amplifier
Where can this be attached in a miata? - Cadence TXA 1000D High Power Mono Amplifier Car Audio Amplifier
  • 323 Answers
You want to run an amplifier kit = rca cables from head unit to the amp, ground to the chassis, power to the battery and remote wire from the head unit to the inside of your trunk. If you have to you'll need to mount your amplifier to your subwoofer box or build a mounting board for the amplifier.
Posted on Jul 28, 2010
Where can I find a manual for 1997 Mazda Miata
Look in the Miata forums. There's a huge amount of Miata fans that can either send you a copy or direct you to a link were you can download the manual. Here's a link that may work for you:
https://forum.miata.net/vb/showthread.php?t=446293.
Good luck! I hope this helps somehow... :)
Jun 23, 2017 | Mazda Cars & Trucks
Tip
How do I Attach my iPod to a Radio in a 2002 Miata
<p> <p>Apple's iPod is a great way to listen to your favorite music in private and comfortable. The transfer of this experience in the private confines of your Miata is a great way to enjoy your music while you drive. Apple recommends a variety of devices that you connect your iPod directly to your Miata radio. Attaching your iPod to the radio in his 2002 Miata is a task Hable accompli given the right materials and installation. <br /> <p><br /> <p>1. Buy a car adapter. Apple recommends a variety of products at a price range and power, the Monster iCar Play Wireless 800 FM Transmitter $ 79.95 Belkin Tune Cast Auto for Live for $ 69.95 in FM Transmitter Griffin Road Trip with Smarts scan for RDS + Power $ 99.95. All products are recommended by Apple, the producer and distributor of iPods and all are available through the online store Apple Auto Accessories.<br /> <p> <br /> <p>2. Attach confirmation that the iPod radio tuner device purchased at the door on your iPod and plug the other end of the device in device port Charger / charger in his 2002 Miata. Depending on the interior options that you selected for your Miata, and the automatic or manual transmission, the device port cigarette lighter / charger is located in the panel below the radio in the glove compartment or center console area between the two banks front. <br /> <p><br /> <p>3. Miata Turn on the radio and choose a radio station with little or no audible sound. Typical among the 90 FM stations are reserved for local stations with low transmission towers, so they are often your best option. <br /> <p><br /> <p>4. Connect your iPod and select the radio through stereo cables to your Miata on your device FM radio tuner. For example, if your radio is tuned to 88.1 Miata, you have radio receiver can be tuned to 88.1. <br />
on Aug 09, 2011 | Apple iPod touch
Cd Player Automatically Ejects Disc
Hi there:
This normally happens when the laser gets dirty and can't read a cd. more common in a smokers car or if living in a dusty area. You can get a cd lens cleaning kit. just a black cd with alike a fake eyelash attached to the bottom side...as it spins it bushes dust off the optical eye of the laser...this is what actually reads the disc.
Other choice, the mechanical system of the player is stuck thats why it cant read the disc anymore, you should put some oil on the mechanical part to lossen some stuck up parts.
Als HERE other Mazda opinnions.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 1997 Mazda MX-5 Miata
1999 mazda miata battery does not have pos or neg stamped on battery and both cables are black so its hard to tell which cables to attach for recharging...
All batteries have to have a + and - or "plus" and "minus" or something.
But all you need to do is take a test light, and ground the clip on any bare metal, like port of the engine. They which ever terminal lights the probe has to be the plus. The engine and all chassis metal is always the negative. I suggest you then get those red and black felt anti corrosion pads for the terminals so that you will know next time.
Feb 20, 2011 | 1999 Mazda MX-5 Miata
I'm trying to replace the thermostat on my '99 miata. is it ok to remove the big hose over the thermostat so i can get to it, or am i going to mess something up?
Thank is how you do it. The answer is yes. There are bolts you will also have to remove that attaches to the motor.
Dec 13, 2010 | 1999 Mazda MX-5 Miata
Miata trouble
it could be a blocked catilytic convertor
Apr 15, 2010 | 2000 Mazda MX-5 Miata
Open gas cap on 1991 miata. can't find the lever
There is a lever to open gas cap in your miata. It should be in the center console between the seats. This is true for my 1990, and since the 1990-1997 Miatas remained virtually unchanged, this should be where it is.
Oct 06, 2009 | 1991 Mazda MX-5
When the top is up I have a rattle
Go to http://www.miata.net/garage/tsb/ and check out the service bulletins there. It might solve your situation.
Sep 21, 2009 | 2007 Mazda MX-5 Miata Touring Convertible
92 Miata transmission shift boot replacement
The lower shifter boot is attached to the transmission by 3 10mm bolts. You will need to remove to center consoule and the upper shift boot that attaches to the car to be able to remove the lower boot. Then you can replace the lower boot.
Dec 21, 2008 | 1992 Mazda MX-5
Headlight outer cover replacement
what should i be getting for gas milage on a 1999 miata?
Aug 11, 2008 | 1999 Mazda MX-5 Miata
Cadence TXA 1000D High Power Mono Amplifier Car Audio Amplifier Logo
164 people viewed this question
Top Cadence Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Cadence Car Audio and Video Expert? Answer questions, earn points and help others
