Question about Vacuums
CANT FIND TELEPHONE NUMBER FOR BELL HOWELL IONIC WISPERER AIR PURIFIER
  • 11,896 Answers
1-800-423-4248 ext. 233
and
1 -800-647-2290
Posted on Jul 28, 2010
Vacuum has power but wont run
From your question it sounds like the Rainbow will not run on high speed. Very good chance the Controller Asm 120v e2 Silver Gold is bad. Call us when you are able as we can replace at a discounted price if your machine meets the requirements. Contact Us
RainVac
Sep 07, 2015 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum has power but wont run.
i have a feeling the motor brushes are worn and not making contact, (no electrical circuit through the main motor).
being as you didn't mention what make or model i'm unable to direct you to a site where you'll be able to purchase these motor brushes... happy hunting.
Nov 23, 2017 | Vacuums
Honeywell air purifier won't turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 23, 2014 | Honeywell UV HEPA Clean Antibacterial Air...
Bell Howell 7650TMO Sunlight Floor Lamp....I need to replace the plug...does it matter which wire goes where on the plug? Only 2 wires come out of the lamp. Thanks.
Yes, it does matter if correct polarity is to be maintained.
Black wire to brass screw on plug
White wire to silver screw on plug
If the plug has 3 prongs (grounding plug), the green wire goes to the green screw.
More info, let me know.
Charlie
Jul 20, 2011 | Vacuums
My silent ionic breeze GP just stopped working (no blue light, no static). only a couple of years old. cleaned weekly. how do I obtain someone to possibly fix it as trouble finding replacement?
http://www.airpurifierrepair.com/ProductDetails.aspx?ID=0&ProductId=473&gclid=CKWj6N--u6cCFYjsKgodLxrBBQ
Airpurifierrepair will fix your unit but it starts at 159.00 flate fee.
Here are some other things to try first:
Dirty Collection Grid.
  • In case of a problem with your Ionic Breeze air purifier, the first thing you should do is clean the collection grid. According to the Ionic Air Breeze instruction manual, the most common problem with the units is that the collection grid gets too dirty and the unit no longer effectively cleans the air. Removing the collection grid from the top of the unit, then wiping it down with a damp sponge or rag, as well as turning the entire unit upside down several times to dump out any dirt from inside the housing, will help restore the unit to maximum operating efficiency.
Glowing Blue
  • Another common problem with the Ionic Breeze unit is that it no longer glows blue, which it is supposed to do when operating in germicidal protection mode. If the unit is no longer glowing, it is likely that the UV fluorescent bulb inside the unit has died or has decreased in output. The bulbs are meant to last for about a year, and touching the bulbs or getting them in contact with oil or dirt will shorten their lifespan. Try replacing the light bulb before assuming there is a more serious problem with your Ionic Breeze air freshening unit.
Transformer or Circuitry Issues
  • Other problems that may occur with the Ionic Breeze that you will need to troubleshoot and repair include transformer or circuitry problems. If the transformer goes bad, the unit will not work at all, and will have no power when you attempt to turn it on. Similar problems can occur if the circuit board is defective. Because of the danger of electrical shock or damage, it is best if you have a repair facility work on your Ionic Breeze unit if you suspect transformer or circuitry problems
Mar 06, 2011 | Vacuums
We owe ionic pro turbo air pur. ever since we cleaned it first time, it's making this static noice and it get really loud at times that it makes hard to sleep. What can we do?
Water or debris in the collection blades or wires can cause a snapping or arcing noise. Water should have dried after a day or so. Look for a hair or lint that is between the blades and wires. Ionic also suggests that the noise may be from misalignment of the blades after cleaning. They suggest removing and replacing the blades to reset the position.
http://www.ionicproturbo.com/images/IP_TurboPro_Manual.pdf
Good luck from Detroit.
Mar 02, 2011 | Vacuums
How do I take apart the air purifier to clean it? I have a honeywell HTT-022 unit and it needs cleaning
Here is the owner's manual:
http://www.kaz-canada.com/kaz/support/manual/?ProductManualAction=renderProductManualById&ProductManualId=ee97a4e6784448b6f57acddb2f29a817
It says first to unplug the unit.
While pressing on the two notches along the front of the grille, pull the grille toward you and remove it.
Gently pull down on the top filter frame and pull forward.
Remove the protective wrap from the filter.
Place back into the air purifier housing and snap filter grille into place.
(This is verbatim from the instructions)
Feb 21, 2011 | Vacuums
I`m looking for a alpine living air XL 15S instruction manual
Hi, I have the air purifier, and on the back of the unit is the number to call to have them send you the manual...it's:
1-800-989-2299
Hope this helps! I couldn't find a PDF one online for you to download it from the site.
Gwen
Aug 24, 2010 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
