Question about Kenmore Elite 45986 Front Load Washer
I hear water in the washer drum & smells. How do I get that water out?
I have a Kenmore Elite HE 4T and just went through this too. My husband took off the bottom of the washer to expose the drain. The black drain hose that comes down from the tub leads into an approx. 4" white "lint" trap that connects to the pump and the gray drain hose. He took off the white trap and it was awful. There was debris and stagnet water-the smell was awful. Needless to say, we removed it and cleaned it and put it back in. Ran 2 cycles of white vinegar and bleach and checked the trap again-it ran clean. I guess what they neglect to tell you is to clean that trap periodically. That solved the problem.
Posted on Jul 31, 2010
  • 5,911 Answers
Residual water in the drum is NORMAL. Since the drain pump and drain lines are at the lowest point of the drainage system, gravity will ALWAYS keep some water in the lines and pump. However, if you have water visibly present in the wash basket, then you may have a blockage in the drain system somewhere. Most often, the drain pump can become clogged with debris over time and need to cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Debris in the drain pump and/or drain lines can contribute to foul odors being present in the washer. In addition, NOT leaving the door open between washes can cause the tub to become stagnant. The manufacturer recommends leaving the door OPEN between washes to allow the tub to air out and to prevent mold and mildew from forming. The following link can give you some pointers on things to do to get rid of odors and prevent them from coming back:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
If you have any questions about these procedures, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Jul 28, 2010
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
Water in the washer.
First I would have posted this in the washer section not the vacuum section. That being said:
This is normal for a maytag Neptune. There is a liquid filled balance ring on the Neptune washer drum. That is the sloshing you are hearing. The smell is from the water trapped between the door seal and drum. You can wipe down this seal with an old cotton towel or sock and then throw it in with your next load. Also, just leave your door open a crack after your loads are done and the water will evaporate and not sit and get moldy.
Jan 26, 2014 | Washing Machines
Sewer smell in the drum
Beat way to solve this problem is, Run your machine on the highest setting and add a cup of bleach, do the same again and add a cup of vinegar, this will clean the inside of your machine and give the water inlets a good clean out. Repeat as necessary.
Nov 05, 2012 | Washing Machines
Maytag Neptune washer always has water in the drum after wash is done? Any ideas? I can hear lots of water left in the washer when I spin the drum manually and of course it has a moldy smell having water...
The liquid is a saline solution which is hermetically sealed in the front balance ring on the spinner. It is there to reduce vibration and acts like a gyroscope when the spinner revolves. Good sound to hear when you spin the basket. The smell can be gotten rid of by using a washing machine cleaner like tide.
Dec 26, 2010 | Maytag Neptune MAH5500B Front Load Washer
There seems to be water being retained in the machine
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there should be whats cauld a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.Alternatively water might be sigphoning back thru the drain hose into the machine.I hope this was helpfull.
Jun 01, 2010 | Samsung WF337AA Front Load Washer
Maytag front load washer - smell musty
the water in the unit is normal, to kill the smell when you are done doing wash for the day dampen a rag with bleach and whip down the door gasket. You can buy a cleaner called "afresh" it works as well. If your unit is a neptune check with maytag it might have a recall on the door gasket for growing mould
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
I noticed that my clothes are not smelling fresh, especially my towels. The washer has a musty smell even after running it with bleach. When I shake the washer when it is empty I can hear water. Is this...
if it is a Maytag neptune YES that sound is normal. especially when you rotate the drum by hand that is your balance ring you are hearing. Do you only use liquid detergent? if yes this might be your problem. it leaves a film around the drum. i would run 3 wash cycles with bleach and hot water. and then at least once a month with hot water and bleach to keep it fresh and also leave the door open so that it can air dry oder causeing bacteria love moisture.
Oct 24, 2009 | Washing Machines
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
AFTER SPINNING, WATER IS LEFT SOMEWHERE IN THE DRUM. i CAN'T SEE IT BUT CAN HEAR IT AND THE WASHER SMELLS BAD.
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
May 31, 2009 | Estate TAWX700JQ Top Load Washer
Stinky washer
I have the same problem. The solution is to use bleach with your whites. It's better to use a normal amount of bleach frequently rather than a lot of bleach only once in a while.
Oct 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
203 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
