Question about Craftsman GT 5000 26 HP54" Garden Tractor ()
I turn on the mower switch and the motor bogs but the blades do not turn
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 146 Answers
Since it bogs down, your PTO clutch is engaging, but something driven by the mower belt is stuck. Turn it off and look for simple things first: look under the mower deck for a branch or object jammed in there, or a bent blade. If that's all ok, then take off the mower belt and spin each of the spindles (the pulleys that drive the blades) and also the idler pulleys. If one if stuck or binding badly, you have found the problem. Idler pulley bearing are inexpensive, but spindles are spendy. Good luck! Please rate my solution if helpful, thanks.
Posted on Jul 29, 2010
Why won't the blades engage on my craftsman riding mower when i turn the switch on. the switch is new and the motor boggs down but the blades don't engage
Make sure the blades are not binding. The issue may be the deck not the clutch or switch. The fact it bogs down when engaged points to this issue.
Apr 09, 2017 | Craftsman Garden
Snapper riding mower
check for a bend blade or perhaps one of the spindles has failed
Jun 11, 2016 | Snapper Garden
How to troubleshoot pto will bog down engine when you try to engage pto
when was air filter and fuel filter changed? are all pulleys turning free? spark plugs good? if everything seems good is motor wore out?
Sep 13, 2014 | Garden
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
I started my craftsman 21hp 42in deck today it had a rough idle with backfire and when engade mower it seemed to not have enough power
Backfiring is a sign of too rich on gas and not enough air. Not enough gas will cause the mower to bog down when blades are engaged as it isn't powerful enough to run the motor AND turn the blades. Check your carb and see if you need to clean it and replace diaphgram. Sounds a lot like a carb problem.
Jun 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Craftsman GT 5000 26 HP54" Garden Tractor () Logo
208 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
