Question about Miller MATIC 140 MIG WELDING PKG w/cart 907311011
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
  • 1,384 Answers
These need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Posted on Jul 28, 2010
I have a Miller Syncrowave 250 DX and it has 3 fans, 1 come on as soon as machine comes on and after welding for about 10min the other 2 come on but they are not
Do you mean to say that the other 2 should come on, but are not? Perhaps you are welding using lower settings than before, and the machine just isn't heating up as quickly. Is there a point at which the fans do come on? Say thirty minutes into the job instead of ten? Maybe you were afraid to run it too long without the cooling fans on and so stopped prematurely, before the thermostat turned them on? Check fuses and breakers.
Sep 01, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
After completing a plug weld on sheet metal the molten weld grows to a point as it cools
This is a gas issue. Either you're running out of gas, or there's junk built up in the tip of the gun, keeping the gas from flowing freely. Also, if your arc length is too short, this can happen but it sounds like a gas problem. If the gas isn't an issue, try backing off a little when you make a weld, or turn your wire speed down a hair.
Jul 09, 2011 | Miller matic 140 Mig Weld Package...
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
Sould like it is running but the switch is still off. you can hear aload buzzing noise.
Your machine must be under warranty still. Please send it back to your welding store and ask for switch warranty repair.
Jan 03, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
My lincoln 140 welds fine on a low setting but when im welding on a high setting the spark starts out strong but seems to fizzle down and it does not burn in good. Please help MIKE
You may be exceding the duty cycle of your welder
Check your operstors manual to see how long you can weld at higher amps before giving the welder a chance to cool down
Oct 18, 2010 | Miller matic 140 Mig Welding Package W/As...
Matic 140 Mig Welding Package W/As 907335: i ware my rollers out quickly is this because of t...
Too much tension would smash your wire and it would not run correctly. Are you sure you are using the correct size rollers for the wire you are using. Rollers come in various sizes and applications. A knurled roller is used for flux cored wire. Make sure you sizes match up. They are stamped on side of rollers. Good luck!
May 16, 2010 | Miller matic 140 Mig Welding Package W/As...
Wire won't feed or arc fan runns
Look for a reset button on the case. Make sure that you have power to the machine and at the power socket. If everything looks ok outside, you may have to investigate your warranty. Good luck!
Jan 04, 2010 | Miller matic 140 Mig Welding Package W/As...
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Miller MATIC 140 MIG WELDING PKG w/cart 907311011 Logo
259 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Robert Monigold
Robert Monigold
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
