Question about Sharp AL-1655CS Laser Printer
I have a code H4-20 on my Sharp ARM277. How do I clear this and be operational again?
3 Suggested Answers
  • 32 Answers
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Posted on Mar 25, 2009
xptareq2000
  • 1447 Answers
SOURCE: sharp arm277 h3-11
Heat roller high temperature detection
Detail :The fusing temperature exceed 240oC
Cause: Thermistor abnormally .
Posted on Nov 21, 2010
How can i clear code h4-21?
Push the 'clear' button and then the 'auto' button then the 'clear' button and then the 'auto' button again.This should be done as quickly as you can and the console will go blank.Next,select 14,which is the low temp clearing code, and then push 'start' and then turn the machine off and back on again.
If the error still occurs call Sharp or qualified technician to resolve your fuser issue
Jun 04, 2011 | Sharp AR-M237 Digital Copier
H4 Displays
H4 indicates "low temperature", possibly caused by a failure of the heater lamp or fuser. Sometimes this error is shown without an actual damage when the power cord is pulled without shutting down the copier first.
To cancel the error code, press [CLEAR], [AUTO], [CLEAR], [AUTO] in rapid succession. The display should go blank. Next, select 14 (clear low temperature code), press [START]. Finally, switch off and on the machine.
If there was no actual damage (i.e. power cord pulled), the machine should be OK again. If the error persists, immediately or after short time of operation, you will need to contact Sharp technical service for repair.
Jan 10, 2011 | Sharp AR-5316 Advanced Digital Imager...
The copier displays H4 What is the solution?
Jan 09, 2011 | Sharp AR-5316 Advanced Digital Imager...
Error h4 sharp ar-5316 can you help me ?
Jan 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp arm277 h3-11
Oct 19, 2010 | Sharp AR-M277 Digital Copier Copier
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Need to clear the key operator code
Have you tried 00000 ? Five 0's is the default key operator code. Press the Custom Settings key then on the display press the Key Operator Programs then 00000 when prompted.
Mar 25, 2009 | Sharp Office Equipment & Supplies
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Unit stops working - E1
I wrote the solution #1 and have an additional comment. This really does work!! I fixed my neighbor's AC unit by following the instructions for clearing the E1 code. The unit will not operate until the code is cleared. The page is titled: Customer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners
Aug 25, 2007 | Sharp AF-S80FX Air Conditioner
Sharp AL-1655CS Laser Printer Logo
66 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
