FixYa.com
Tags:
RCA D52W19 52 in. Rear Projection Television
Big Screen TV RCA Bought at Wal-mart (by 4 users)
posted by Simmons01 on Apr 24, 2008
TV power light will come on but, while something I assume is warming up the T.V. will shut off. Then it will try again but, same thing when screen is suppose to start it turns back off. Any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by lecram, posted on May 30, 2008
when i press the power botton the light flashes 3 times and the tv never comes on
its a 52"RCA HDTV bought in 2004 from walmart
Comment by heavydtb, posted on May 18, 2008
I'm having the same problem. I'm replacing the fuse to fix the convergence and now the TV just turns on and off over and over
Comment by Guest, posted on Apr 25, 2008
Best Solution
posted on May 02, 2008
FixYa! (100)
tique53
Rank:Guide Guide
Rating: 68%, 8 votes
Here is what I found on my set: The capacitor near the H out was loose of one of its ends,resoldered and it comeback to a normal function. I hope it helps.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jun 16, 2008
Not Rated (0)
mrbigmoney
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This problem is definately caused by the transisitor and unless you know where it is located, need to have a technician fix it. The tv shop we normally use told me the transistor RCA 259856 wasn't in stock and it would take two weeks. I google searched for the generic # of the transistor #17N80C3. Digikey had them in stock and I had it shipped to the shop. I had my tv in 3 days instead of two weeks.
Solution #3
posted on May 29, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Check Capacitor CP150 known to go bad
Can you Help with these Projection Televisions problems?
d52w19 - A thrill a minute
Ok guys.. here we go... I have... Answer This...
power supply problem
How difficult is it to get this... Answer This...
rca d52w19 floor model flat...
when i turn my tv on theres... Answer This...
Problem with Surround Sound...
We have a Mirage surround sound... Answer This...
need help with screen........
I also had an issue with my... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
