Question about Canon imageRUNNER 400S Copier
I HAVE IR 400 COPIER COPY IS TOTAL BLANK ,I HAVE CHECKED DP , DP PRESSURE,MAGNET ROLL IS OK. BUT COPY IS BLANK WHY?
  • 1,219 Answers
Hello, firstly I would check the laser station shutter. When the door is closed the laser shutter must be lifted up to realese the cover of laser unit, so that laser could write on drum.
Also try to copy one page and open the door when the paper is in position beneath drum. Then look at drum, if the "picture" is on drum, that means that you have transfer issues.If not on the drum check laser shutter.
Hope that helped.
Posted on Jul 29, 2010
How do install toner IR 400 canon
Open machines front door,
pull down developer-units (DP),(toner cartage) handle,
remove DP fill New toner ....
simple
Mar 09, 2015 | Canon imageRUNNER 400S Copier
How to clear RAM using factory settings in CANON IR330 machine?
ir 330 and ir 400,gp 405 r same machine,turn on the copier when its ready to copy press the additional function then press (2 and 8 both r same time) again additional function when this process is completed copier on the screen select that in the screen find the 'function' select then select on clear in clear menu select one by one err and other all function like dc-con and press ok after se;ect one by one..
Sep 02, 2011 | Canon ImageRUNNER 330s Copier
I have a panasonic dp 8016 copier and i m facing the peoblem is there is no image on drum and copy is like blank paper i change the developer,drum,and cleaning.but still the same. please help me to fix...
have u taken out the internal report out .if the internal report is ok then u have to check the optics .check whether the lamp is working or not .also chek the mirrors. if the internal report is not ok then u have to chek the laser unit as it can also be faulty
Aug 24, 2011 | Panasonic DP-8016P Copier
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Canon ir 5570
Replace carona wires or change primary charge unit
Feb 10, 2009 | Canon imageRUNNER 5570 Copier
Canon ir 400 copier
Check the scanner. If the lube has dried up it could be causing the scanner to vibrate slightly when reading the image.
Oct 14, 2008 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 400S Copier Logo
118 people viewed this question
old marine
old marine
