Question about Blendtec Extra Carafe / Jar for the Total Blender (Blend-Tec) Blender
The blades on my blendtec jug are stiff, any way to loosen them?
    Problem Solver:
  • 8 Answers
What you need to do is turn them by hand each time you use it, before you put your food in. Sugars and other deposits are often left around the blade assembly when you mix smoothies and stuff. Often this sugar is difficult to clean. Turn them by hand first to break the sugar molecules, then when you are done I would add 2 inches of water and a drop of soap. Run it for about 20 seconds and rinse. That should help the next time you use it. It also helps to use it daily. It keeps the molecules from hardening.
Posted on Jul 28, 2010
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
Does anyone know how to reset a Blendtec ICB-3 to factory settings?
ust removing all power from the machine for 15 secs or more should reset it.You can contact Blendtec here, Not a solution I know sorry. The manual is here http://www.blendtec.com/Resources/A3-31E-BHMV/Connoisseur%20Manual.pdf
you can contact them here
http://www.blendtec.com/contactus.aspx
Jan 03, 2011 | Blenders
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
My blendtec blender doesn't blend as well as it once did. The motor seems to be running fine, but I am not sure if the blades are spinning properly.
You have already found what is the problem the blades.
The blades after a lot of working hours with ice they have mainly three problems.
One the sharp adjes have created a lot of teeths and are not so sharp any more so the blending is not smooth anymore.
Second problem they have loose a title so they have move from corect place some milimeters and this change the wave motion and again the beleding is not so smooth as before.
Third the blades are secure on an axis which is located in two bearings which have een wearing out so the rotating motion of the blades again is not so smooth as before.
So if you are not able to fix the blades kit or to find someone in your area to do it profetionaly and cheap one good idea is to buy a new blades kid.
Good luck
Aug 17, 2010 | Blendtec ABC Work Top Blender
Blendtec replacement jar
You can also go to http://veggiesensations.com to buy blendtec total blender parts. Hope this helps!
Jun 30, 2010 | Blendtec Extra Carafe / Jar for the Total...
How to change the blade
You can't. The Jars have perfectly balanced blades that cannot be changed. A replacement jar from Blendtec is cheaper than a replacement blade assembly from other manufacturers. 1-800-253-6383 is the customer service number.
Jun 04, 2010 | Blendtec Smoother Work Top Blender
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
What to do with the Total Blender when overload appears?
The product has a 3-year warranty:
A reading of “OVERLOAD” indicates an overload on the motor. Turn off
and unplug the unit. Plug in the unit and turn the motor on again to clear the
over-load condition. Check the blender jar for blockage. If overload condition
re-occurs, contact your Blendtec service agent.
Mar 25, 2009 | Blendtec ABC Work Top Blender
Blendtec blender jug split
I wouldn't fix the jar, just buy a new one. A crack, though rare, could possibly harbor bacteria. You could try using heat and melting it, but it wouldn't work as well. Your jar may still be under warranty, call Blendtec at 801-222-0888
Feb 24, 2009 | Blendtec Extra Carafe / Jar for the Total...
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Blendtec Extra Carafe / Jar for the  Total Blender (Blend-Tec) Blender Logo
1,238 people viewed this question
Top Blendtec Blenders Experts
eyecam
vince
Jeff Tilburn
Jeff Tilburn
Are you a Blendtec Blender Expert? Answer questions, earn points and help others
