Question about TallyGenicom 6306 Matrix Printer
Tally genicom 6306 paper out error message let me do what? Please help! thank you in advance.
    Sergeant:
    Habit-Forming:
  • TallyGenicom Expert
  • 124 Answers
This sensor can be re-calibrated.
Press LF and Enter for 5 seconds to enter Tech access mode.
Press menu scroll to test then press enter.
Scroll to Diag and press enter.
Scroll to cal-paper and press enter.
Scroll to paper out calibration and follow onscreen prompts.
If it still fails replace the sensor.
MRP provides IT Parts Product Supplies and Services
Posted on Jul 07, 2015
Techvisitor
  • 63 Answers
SOURCE: error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Posted on Oct 31, 2008
SOURCE: paper width error on tally genicom 2280+ printer
Power ON printer holding down ONLINE button, release it after TESTMENU is on display. Press NEXT few times, enter APM or somthing like that (or APW? cant remember), switch it to OFF. Press ONLINE. Thats it! Greetings.
ps. this is procedure direct from polish division of tallygenicom servicedesk. it works for me perfectly!!
Posted on Jan 28, 2009
SOURCE: SVC E9 ERROR
butta via la stampante e prendi una hp
Posted on Jun 11, 2009
  • 169 Answers
SOURCE: I own a Tally Genicom
The error indicated on the 8008, ‘SVC E9’ indicates the printer is not detecting the OPC Belt as rotating in the printer. The printer ‘looks’ for two black squires on the left side of the OPC Belt (as viewed from the front of the printer) if the printer does not ‘see’ black squires the printer indicates the SVC E9 error.
If the printer is displaying the SVC E9 error the most likely cause is something to do with the OPC Belt, normally removing the OPC belt from the printer then re-seating the belt would resolve the problem in most cases, as the OPC belt may not be locating correctly in the printer.
Unfortunately you have already removed the OPC Belt from the printer without resolving the problem, it may however be worth removing the OPC belt again and to look at the green reflective surface to see if there any damage or if the green surface is fairly central and is no skewed or bent in any way.
Depending on which position the OPC belt stops in you may see the black squares down the left side of the belt, if you can see these and they don’t look damaged or scratched the printer should detect the OPC belt ok, so the problem may lie with the sensor on the printer its self.
Posted on Sep 18, 2009
allanhunt
  • 135 Answers
SOURCE: DRIVER
Try this link:
http://www.liutilities.com/device-driver/tallygenicom-6306/
Posted on Mar 28, 2010
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before.
In Lipi 6306 line printer "Checksum fault block 8".It is not going on offline.What should I do now.I have not faced this type of problem before. os window xp
Aug 29, 2013 | Office Equipment & Supplies
I have problem to creat a form 14 *4 in tally genicom 6306
Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
As the paper size defined is wider than the capability of the printer, you do not see this paper size within Windows.
The solution to the problem may be much easier than you might imagine as it is very unlikely you actually want to print 15 inches wide, you more than likely want a paper width of less than 13 inches but are including the sprocket holes and margins at the side of the paper.
Simply define a paper size the width of the printable area of the paper, so long as this is less than 13.6 inches you will then be able to select this within Windows.
Sep 10, 2012 | TallyGenicom 6306 Matrix Printer
In our office we want the printer tomsupport the paper size 15*12. We create the paper size. but it is not displayed while setting the paper size for printing. Our printer is Tally Genicom 6306
Ok, I think the problem you are having is when printing from a version of Windows, basically the problem is the 6306 can only print 13.6 Inch Wide, it looks like you are trying to define a paper size 15 inches wide.
Jan 08, 2011 | TallyGenicom 6306 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Lipi 6306 Line printer
i want to knwon the which operating system supports the lipi tally genicom line printer model 6306
Oct 16, 2008 | Office Equipment & Supplies
Paper width error on tally genicom 2280+ printer
Mar 12, 2008 | TallyGenicom 2280 Matrix Printer
TallyGenicom 6306 Matrix Printer Logo
1,038 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
