Question about Kyocera CS-2050 Black and White Copier
My customer has a Kyocera Cs 2050. The screen says print mode error. Can you tell me how to fix this problem.
    Brigadier General:
  • 3,917 Answers
Hi
Try setting the driver to KPDL mode in the settings section of the drive. Print Mode Error can indicate even the "simplest" of conditions. For example, the cassette runs out of paper. Have the user press the PRINTER key and OK, the display will show the reason for the "PRINT MODE ERROR" condition.
"Print Mode Error" also occurs when the machine receives data to print a specified paper size the machine does not contain. Example, if the machine is set to print on 11 x 17 and that drawer is empty, you'll get that message. However, the most common cause of this message is when whatever program you are printing from sends an oddball size to the printer such as A4, Folio, 16K, etc. The next time you get that message, press the Printer button and see what paper size it's asking for. Then make sure the program you are printing from has Letter or Legal or Ledger or whatever size you want to print on is set.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 28, 2010
Kyocera km-2050 print mode error
Print Mode Error is Chenglish for a problem with printing. Press the Print key at the left side of the panel, then the display should tell you to add paper etc
Dec 31, 2013 | Kyocera Mita KM-2550 All-In-One Laser...
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
My kyocera cs-2050 will not allow me to print on two sides. I am unable to click on the box in the properties
First of all make sure you have the optional DU-410 duplex option on your machine. If you do not have this optional accessory installed you can not automatically duplex. If you are sure you have this option then go to the printers properties screen on your computer and you should have an advanced tab which has the options listed. Make sure the duplex option is installed. Once you have checked these 2 things you should have your question answered.
Good Luck and Thank You for using Fixya.
Jun 09, 2010 | Kyocera CS-2050 Black and White Copier
Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Jan 29, 2010 | Kyocera Mita KM-2050 Printer
I'm try to print a PDF file by Kyocera CS-2550 but after i press print button it's not print and in the kyocera screen I see Print Mode Error
change the driver from kpdl to pcl xl, this is normal problem with pdf files. you do this from ur computer driver.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 16, 2009 | Copystar CS-2550 All-In-One Printer
Cannot setup/connect to Kyocera CS-2050
go to kyocera mita america online. they have all the drivers. you need the KX driver
Jan 21, 2009 | Kyocera CS-2050 Black and White Copier
CS 3035 printing problem/network issue?
Check the sleep mode settings on it. Do you know how to check on Kyocera's tech website to see if there is a firmware upgrade available?
Sep 17, 2008 | Kyocera CS-2050 Black and White Copier
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Apr 09, 2008 | Copystar CS-2050 All-In-One Printer
Kyocera 2050 Has set toner error
Take out the toner and clean all contacts that you see. and make sure that it is seated properly. if the contacts are not touching it will not see the cartriage.
Aug 13, 2007 | Kyocera CS-2050 Black and White Copier
Kyocera CS-2050 Black and White Copier Logo
151 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
