Question about Haier Televison & Video
HLT71 When autoscan is complete, I receive numerous RH channels, but only 4-5 viewable stations. I live outside CHI and can't receive channels 2, 7 or 9. How do I obtain the latter channels?
    Genius:
  • 1,340 Answers
Press the menu button.Go to the scan button.Manually enter in the channel you wish to add.Press the volume or channel button to 'add'it and if you press it again it will show delete(probably volume,many different brands have different ways to do it yet still basically the same).Do the same for all the channels you want.I use delete for channels such as C-span and a couple of other nonsense channels I do not really care to watch.Even if a channel is deleted,you can still watch it by manually entering the channel number on the remote.After you finish,hit menu to exit the setup.
Posted on Jul 28, 2010
How do I get the autoscan to save during initial setup?
Autoscan won't save if it can't sense any stations. There may be a faulty antenna or cable connectiopn
Oct 05, 2015 | Initial Televison & Video
I am receiving a no data base message
It says no data base because it has not found any channels that are acceptable.Not all areas of the country or the world would have the same base of channels so that is why it has none when first used.It needs to scan the air waves to build the data base for its current location,if you were to move or take the HLT71 on a trip you would have to do this again. Also unless you live in a highly populated area you will need to use an outdoor hdtv antenna as the that comes with it is not powerful enough.The TV is great but the digital technology used for broadcasting is just not that good yet. Good luck and I hope this helped.
Sep 03, 2011 | Haier HLT71 7 in. Portable TV
The problem with the tv is that it is no longer able to be turned on. i have tried many different outlets and that is clearly not the problem. also, the power system that came with the tv still has a green...
Hello
Connect the TV to external antenna or cable and do the following ot autoscan channels. If it autoscans, and doesn't store any stations in its memory, the memory IC has damaged and should be replaced with same type and number. Wait till autoscan completes and see whether the first channel receve will comes displayed or not. It will take some time to complete. the procedure is:
From Menu Press Vol [+/-] then Channel [UP/DOWN] buttons to find CHANNEL AUTOSCAN.
Press Volume [+/-] button, channels will be scaned automatically. OK
Jan 11, 2011 | Audiovox FPE1505 15" LCD TV Television
My set top box will no longer pick up certain channels such as itv and channel 4 stations !!
My set top box has setup menu, channels, autoscan to scan for channels. They changed some of the channels here after the original switch to digital, and a fresh autoscan was needed to again find the channels that moved. See if your box has autoscan for channels, and do it.
Dec 28, 2009 | Televison & Video
Hdtv qam tuner
More often than not the problem is with the Cable co. They ALWAYS blame the tv. I have had many many problems with the signal quality coming from that co. Here is the most likley cause. The cable signal is probably very Weak. This can be caused by a weak signal coming from the cabls co. or a bad cable inside your home. The age of the cable can effect the signal quality.Note: The cable co is only required to provide a Digital signal. Some companies allow free HD signals and some charge for that signal. The correct approach to this issue is to get with the Cox and ask the if they provide free Hd channels without a box. If they say no then you will have to get a HD cable box to watch HD programs. Themn if they say yes then you need to ask them to send out a tech and test the signal coming from the Head End all the way to your set. If the signal flucuates then you will get inconsistant scanning results.
Jul 04, 2009 | Samsung LN-T4665F 46 in. LCD Television
Since Texas went digital I am only getting some of the digital chanels. I have changed it to digital programming but they are not all coming through. What do I need to do?
we need more information:
1) Your city in Texas; so I can look up the stations and find what frequency's they are broadcasting their DTV on.
2) What kind of antenna do you have ?
VHF ? UHF ? Inside ? On the Roof ?
A couple things you can try:
- instead of having the TV AutoScan for channels, manually enter the channel for the TV stations not being received.
- call the TV station you're having trouble receiving: they will ask you where live, what kind of antenna you have etc..
but you really should have a 'roof mounted' antenna that is matched to youre reception needs.
Jun 16, 2009 | RCA TruFlat 27F520T 27" TV
Analog / Digital stations
Hello mikekahan,
OK you are not going to like this but here we go any way. First of all I need to explain how your channels are created.
When the RF signals come into the headend of the Down converters they are separated into pre channelized designations DC (Down Converter) 4 Stream 1 (DC 4-1, DC 4-2...) now once this is done the down converter signal is fed into a channel processor which takes the incoming signal from the Down Converter remodulates it and puts it on an assigned channel 4-1 could become channel 4, 4-2 could become channel 5 and so on. Once this is done you end up with your regular channel line up for analog channels, now for digital its a little different you have IRDs (Integrated Receiver Decoders) which take the off air or satellite Digital RF signals and convert them into MPEG Streams which is the fed into what is called a SEM (Motorola Architecture) Stream Encryption Module which assigns numeric designations to the MPEG streams and then converts the MPEG streams back into RF. Now at this point we have analog and digital signals what then has to happen is the the analog signals must be turned into MPEG streams to go through the system so what happens is from the channel processor the analog signal is put into a SE (Stream encryptor) Like the SE1010. This takes the analog stream and turns it into am MPEG stream and feeds it into the SEM also and the SEM assigns a numeric designation just like the digital signal and this can sometime follow the same numeric designations as was obtained from the Down Converter, So what you end up with is analog and digital signals having the 4-1, 4-2, 5-1, 5-2, ..... format. This is where other equipment comes into play These designations are then kept in a database and are matched to their proper channels by use of the DAC and RADD along with an IPG server. These allow the SEM to assign true channel designations to the converted channels, now the SEM DAC, and RADD talks to your STB, this is way the channels are correct because the SEM and the DAC/RADD are matching what is on the IPG (Interactive Program Guide). When you remove your cable box the tuner in your TV does not know how to deal with the DAC, RADD and IPG signals so it only displays the RF information which is the 4-1, 4-2, 5-1, 5-2 data.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 27, 2009 | RCA 20F424T 20" TV
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
Feb 19, 2009 | Televison & Video
No signal after autoscan for channels
Tv stations main channel is an addition of 1 (04-1) but can have up to 5 stations (4-1, 4-2,4-3,4-4,4-5). They may not have anymore then one, it is their choice. PBS usually has 2 or 3 channels
Jul 01, 2008 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
443 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
