I bought a 32" conia tv and i cant get good reception! i have bought a amplified antenna and a hd set top box and still no good reception. my other tv's in the smae spot have had no reception issues. what could be my problem?
  • bennaiboi Apr 27, 2008
    thanks for your help! the thing is, i have had many tv's in this exact same position of the house before, without amplified antenna's that have provided me with perfect reception. I was hoping you would know something about this particular TV because i suspect it is the problem
    Sergeant:
  • 395 Answers
Well it's the same as the days of old, the antenna has a range of reception. the further the sations antenna, the lager your antenna must be. just because you bought an amplified antenna does not mean you will receive the deep fringe station. also the antenna must be UHF and VHF to receive the broadcast in digital. most of the braodcasters have gone with the UHF band because it is more stable for the bandwith of digital broadcast. the UHF band is very directional as well, so you must be pointing to the broadcasters antenna. no set top antenna will work if you are further than 15 miles of the broadcasters antenna. the roof top UHF/VHF antenna with a preamp is the way to go. I have tested every compact antenna and unless you live in the city that the broadcast generates you will get no reception with these. terks are junk, and any small amplified antenna does not work if you are in low lying areas. roof top, roof top,.....ROOF TOP!!!!!
Posted on Apr 24, 2008
  • Robert Johnson Apr 28, 2008
    well the thing is that I don't know the particular tv you have since you didn't post the make and model. the other thing is the fact that most of the tv antenna's you may have used are VHF only and the Digital uses UHF ( differant type antenna). rabbit ears are VHF and amplified antennas only produce the best results for VHF only. you need to get the UHF type antenna to get the best results in the digital broadcast. also like I said it is very directional your antenna must be pointing at the broadcasters antenna. do not think of this as the anolog world where just a little signal will produce a snowy picture that you can fine tune, you must have 35 to 40% of the signal to get the picture. I have shouted from the roof top and that I hope all can hear!!
Is the Ematic AT103B Converter Box compatible with Suddenlink cable/digital service?
No, the Ematic AT103B is an over-the-air digital ATSC tuner and will also can convert the digital signal to analog NTSC for older TV tuners. It will not work with any cable service and is for "cord-cutters". The AT103B requires an antenna to receive your local OTA channels. Depending on where you live, you may get some channels with an indoor antenna. You will get better reception with an outdoor antenna. See http://www.tvfool.com or http://www.antennaweb.org for details on the channels you can receive with an antenna pointed in a particular direction.
The Ematic set top box does provide an HD signal output and a DVR (time-shift function) so it is more advanced than the first generation OTA converter boxes. The original (available with the government coupon) converter boxes only gave an SD output.
I hope this helps.
(antennaweb.org gives a very conservative list of available channels but assumes an external antenna. tvfool.com lists the channels that are likely to be received with a variety of antenna strengths. An antenna signal amplifier can improve the reception. (Digital stations will not be seen if the tuner can't lock onto the signal.) However, when the amplifier fails, you may find some channels will not be received at all.)
Dec 08, 2016 | Televison & Video
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Ge antenna 24700
Hi Patrick,
A fuzzy signal on a plasma TV is not common anymore as with the lack of analog TV transmission the signal is either there or it is not.
A amplified HD TV antenna is not always a solution and often times to get a good HD type reception a good outside antenna is required. I have two $100 antennas high up on my roof and still you can get a loss of data stream when the weather is bad. I also use distribution amplifiers to feed several TV's
In the case that the picture is fuzzy but still there it might be a resolution setting that is wrong so hit the menu button on the remote and see if that display is clear- if it is then try setting a different resolution for the input that you are getting fuzzy signal on.
Aug 10, 2012 | Televison & Video
Ever since digital TV started, I have had a problem with my picture occasionally glitching/pixilating, plus the sound freezes when this happens and I lose part of the broadcast. I currently have an HD TV...
Basically you are not going to get good quality TV reception on an internal antenna unless you live very close to the transmitter aerial with no significant metal structures (including buildings) in the way. You may get a slight improvement by placing the antenna near a window and away from any large pieces of metal or other electrical devices, especially any with a large magnetic field (anything with a motor in it). You may improve the signal / noise ratio by making sure that you have good quality, foil screened (satelite grade) cable between your antenna and TV set.
If the building has a (shared) roof top antenna you might get a better signal, which can be boosted using an in-line signal amplifier from that - but only if it is pointed at the right transmitter. However, as you will be installing the amplifier close to your set it will (just like the amplified antenna you are using) also amplify any electrical interference picked up by the cable as it passes down through the building - including from cars outside.
However your best bet is going to be cable or satelite TV
Feb 17, 2011 | Terk FDTV2A Omni Directional Amplified...
I have just bought the Bush combi A322d hd ready lcd 22 inch tv/dvd. I have tried several times to tune it in but it doesn't tune in all the digital program properly that I had before using a standard tv...
Is your antenna "omni" or "uni" directional? "Omni" means you won't have to aim the antenna but "uni" antennas have to be pointed in the direction the nearest tower/s. You'll want to go to AntennaWeb.org and enter your address. This will show you locations and distances of TV towers in your area. My location is over 39 miles from any tower so I get virtually no reception with regular HD antenna. If your more than 20 miles you'll need to get a fairly high gain antenna and have to aim it in the direction of the TV tower.
Nov 19, 2009 | Bush Televison & Video
Digital Signal on my Conia TV has gone. Cant access menu for DTV
I would guess that you are using either cable or satellite for reception. If that is the case, the signal is already a "digital" one. The digital reception you are attempting to receive is the over-air broadcast signal that was implemented recently. This change-over only effected those using external antenna connections. Cable and satelite systems have not changed.
Hope this helps,
Dan
Jun 18, 2009 | Televison & Video
Digital conversion
You are in good shape; the specs state that your model has an ATSC compatible tuner so you can receive either analog or digital.
BTW, if you are receiving via an antenna and have decent UHF reception (chan.s 15-69) you won't have to do anything. If you are on cable or satellite dish, they may charge extra for HD reception and a replacement cable box. Otherwise you'll just continue to have those black bars left and right.
Mar 21, 2009 | Protron PLTV-32 Television
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
I purchased an Insigna HDTV (or so I thought) at Best Buy a year ago, anticipating the February 09 conversion. I also bought a HD specific antenna, since I don't subscribe to either cable or the...
I was not aware that there are HD specific antennas. But, that aside, I don't know enough to answer without the model number of your set and information about the antenna, such as how you have it connected, is it amplified?
Best Buy is usually pretty good about helping with solutions. Have you called or visited a store? Be sure to ask for the Geek Squad person/s that are specifically assigned to TV's. Also most of their Dept heads are pretty knowledgeable concerning conversion and the associated problems. My apologies for not having a better answer.
Sam Bass
Nov 19, 2008 | Televison & Video
Antenna for my HDTV
Special HD or Digital antennas are not required to receive digital stations. A good VHF/UHF antenna should work. Try an amplified antenna for the best reception. Most antennas have a coax type connector which should connect to the ant. in jack on the back of your DirectTV box or to your tv depending how the box is connected to your tv.
Jun 25, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
Electro Med Services...
