Question about Motorola Mobility RAZR2 V8 Cellular Phone
I have a black screen inside and out....how can this be solved.......
    Genius:
  • 1,478 Answers
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Posted on Jul 28, 2010
I have a sony dsc h200 but it won't power on the button turns green where the power button is but nothing shows on on screen it's just black no icons how do I fix it?
Checked INSIDE battery connections, perhaps voltage are SHORTAGE or cleaned your camera INSIDE circuit board, your problem are solved.
Jul 19, 2016 | Computers & Internet
How to solve the acer monitor black screen orange stand by light issue
Hello, your VGA Cable, HDMI Whatever cable you use to make your monitor show screens, you must make sure the VGA (only) is securely secured into the socked and screwed in, sometimes the little rods inside may be bend and this can cause this to occur. HDMI cables may not work do to it being broke ect. Same with VGA.
May 01, 2014 | Computers & Internet
27 inch mac condensationon inside of screen
This problem is well known with imacs.
You can solve it if you have two suckers to take off the glass. You put them on the glass in diagonal and pull carefuly. Just have to wipe then.
Feb 11, 2012 | Apple Computers & Internet
My phone is on and works fine, all except the screen is black and I can't see anything. This is no water damage
Hi, it's not a water problem,but a flex problem.is because there is a flex inside that connected to the screen of the phone that makes the phone display is faulty and it needs to be replaced so that the screen can display.
When you replace the flex, problem solved.
Take care.
Oct 18, 2010 | Motorola Mobility Rival A455 Cell Phone
The flip screen is black
Hi, what makes a phone screen black is because the flex of the phone is damaged and will need to be replaced.
The flex of the phone is located inside the phone ,it's connected to the screen of the phone and it makes the screen displays.
Replace the flex and problem solved.
Take care.
Oct 06, 2010 | LG enV3 VX9200 Cell Phone
F-o5 flashing on screen with load in it
F05 means that the pressure switch is jammed on full.
to rectify the problem, do the following.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum
Remove and clean the filter inside the hose.
Remove the hose on to the pump,, and check here for obstruction,and look inside the pump as well.
This should solve the problem.
Dec 01, 2009 | Hotpoint Washing Machines
Tiny black dots on tv
This prob.can't not be fix U have a radiations leakage screen prob.The only way to solve this is to replace LCD screen itself,not worth the money,just junk it.
Aug 23, 2009 | Televison & Video
Lenovo S10 Series Turns on But The Screen Stays Black?
Take out your battery and hold down the power button for 60secs... This will release any excess charge built up in the machine.Put the power back on but without the battery,just plug the adapter and if it turns on then you know what's wrong.You need a new battery.Make your laptop light.Make sure you don't have anything attached to the Laptop and then restart. It could also be your hardware [motherboard,graphics card,screen] problem,if you can,try tightening the screen connection from inside. If that also doesn't solve the problem then you need to go to the company service center.
Jul 17, 2009 | IBM ThinkPad T42 Laptop
Black screen on camera
did you drop it?, most likely this occurs of people drop their cameras and the inside connection dislocates. simple solution is to take it apart and fix any loose connection on the lcd and put it bak together. if that doesn't solve it, order a new lcd for it, unless if it's lesss of a hastle getting a new camera
May 20, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Unable to watch full screen
While watching a video on YouTube, right click inside the video and remove the tick mark for enable hardware acceleration. That will solve your problem. Its a problem with Adobe Flash Player.
Mar 25, 2008 | HP 510 Notebook
Motorola Mobility RAZR2 V8 Cellular Phone Logo
207 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
