Question about Pride Jazzy Select 6 Indoor Power Wheelchair
I need to know where the wires go on the charger plug in. My 7yr old pulled the cord off the wheelchair by the wire not the sliver end and the wires came out. I can fix it I just don't know where the white wire goes. Thx Rod
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hi,im disabled myself,please rate me with a thumbs 1 to 4 as you feel ive helped.visit:www.alldatasheet.com & download the PDF File for your needs,hope i was of help Colin.
Posted on Aug 02, 2010
How do I get my pronto m91 out of charging mode?
The M91 has an onboard charger. When unplugging the charger power cord from the wall outlet does not stop the chair from being in the charge mode, The charger has to be unplugged from the wheelchair wiring harness or main control module under the plastic body parts. The on-board chargers fail like this sometimes.
Jun 06, 2014 | Invacare Supply Group Invacare Pronto M91...
Do i have to have the powern button on to charge my jazzy 600?
nope. The charger automatically removes power when the charger is plugged in. If it doesn't then there is a broken wire in the charger cord where it connects to the scooter.
Apr 25, 2014 | Pride New Jazzy 600 Power Wheelchair by...
Batteries don't last
Check the battery connections to the wire ends for corrosion and tightness. Take the wires off the battery and remove any obvious corrosion. Take a knife blade and make the wire end shine and the same for the battery terminals. Reassemble the wires to the battery and tighten.
Jan 12, 2014 | Pride Go Chair Travel Power Chair
I have a HP8204B Pride battery charger 24vdc 5a 230vac, the wire to the end connector (3 pin with 2 of the pins bridged) has come away and i don't know which wire (one black, one red) to solder to which...
The red wire is positive and is soldered to pin 1. You can see the 1 on the pin (non solder side) of the plug housing or on the solder side as a raised stamp 1.
The black wire is soldered to the negative pin 2. Two of the pins are bridged to inhibit the power chair operation when the charger is plugged in. Hope this helps.
Mar 16, 2011 | Health & Beauty
I need to know how to charge the batterie om my sisters merits wheelchair,i do not know how to plug it up,,or if the charger is located on the frame someplace or if its freestanding.plain and simple i do...
sking the off board charger is a 5 inch by 3 inch rectangular box with a power plug on one end and a round silver 3 prong plug on the other. The charger plugs into the charger port located under the front of the joystick. Plug the charger plug into the joystick and then into the wall socket. When it is fully charged the light on the chrager will turn from yellow to green. Unplug the power from the wall socket first then unplug from the joystick In ither words always have the charger unplugged when you plug the charger up to the chair Now if the chair has an onboard charger there should be a power cord that just plugs into the chair usually somewhere in the rear of the chair all you have to do is plug it into a wall socket and charge away Hope this helps you
Mar 10, 2011 | Electric Mobility Merits Electric...
Have a Sunrise Aspire chair w/new batterie, charged by the repairman. Want to keep it charged regularly (not let it run down). DO I NEED TO TOTALLY DISCONNECT THE POWER HOOKUPS IN THE BACK when I...
You do not need to unplug the large 9 pin beau plug in the rear or the smaller 3 pin molex plug when you charge the chair. Do not unplug them or you will not charge the chair.
Use your charging cord as you describe "plug it into the front, plug it into the wall and charge, then unplug the charger cord and GO". Hope this helps.
Jan 05, 2011 | Quickie Wheelchairs Quickie Aspire Power...
What is the 3 prong outlet on the side of my chair for? Is it a charger?
If you have an on-board charger for your power chair this outlet is for your charger cord. One end of the AC cord plugs into the wall outlet and the other end plugs into the trapezoid shape outlet on the side of the chair. This is the same shaped AC cord used to power computers and other devices. You can buy one a most hardware stores and places like Radio Shack. If you are using an off board charger which plugs into the front of the joystick (round plug)to charge the chair, then you don't need to use the on-board one and you don't need another AC cord. Hope this helps.
Dec 04, 2010 | Jet 3 Ultra Power Chair
Hello, i have a invacare wheelchair that has 2 12v sealed batteries, wired in series at 24v. I wanted to find out the charge plug has 3 prongs, which should be -. ground, . over vice versa, how come there...
Salty The charger detects the batteries when it is plugged into the charger port. With the older chargers you could measure the output of the charger by measuring across the two outter pins. With the newer chargers there is no output until the charger is plugged into the charger port. Now on the M51 you should have an on-board charger and the cord plugs into the back of the chair into a three pronged plug. Now if you plug the on-board charger into the wall socket and look at the rear of the chair low to the ground you should be able to see a red and yellow light (red and green when fully charged). With this charger plugged in you can take a digital voltmeter set it on 200 v dc and plug the leads into the two outter holes in the charger port under the front of the joystick you should read 27-30 volts when charging and 24-27 volts fully charged and the charger unplugged. Hope this helps you
Sep 20, 2010 | Invacare Pronto M51 Power Wheelchair
Not charging
If you have power to the on-board charger, check inside the base and be sure that the wires to the amp-meter are tightly connected and all other connections are tight. If so, then you probably need a new charger. Instead of paying a few hundred bucks for an on-board from the mfgr. you can buy an off-board charger on ebay for around $50.00 that will plug into the 3-pin connector located on your joystick.
Just search ebay for electric wheelchair charger and you'll find dozens; make sure you get the one with 3-pin connector...most are like that.
Dec 05, 2009 | Jet 3 Ultra Power Chair
Hoveround cannot be used
You need to get 2 sealed batteries, U1 type, and you will need a ****-splice connector to splice the broken wire together.
Nov 27, 2009 | NRS Hoveround MPV 5 - Used Power...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
55 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
