Question about Refrigerators
I have a whirlpool dryer Model GE/GQ8858J and it is not heating at all. It is 10 years old and I don't know if it is worth calling a repairman to come out. Any advice?
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
  • 178 Answers
SOURCE: HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Posted on Mar 18, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Dryer Model # DPSR473EWOWW SQUEAKING
If the squeaking has been going on for only a short time, you may be able to get by with only replacing the rear drum bearing, but if it has been going on for some time you should replace the drum bearing kit part # WE25M40. Also be sure to check that the front drum slides are ok, especially the one on the left side of the front drum support, as this one wears out faster. Drum slides #
WE1M481 and
WE1M333 and if front support frame is worn so that there is nothing left to hook the slides into you would need a
WE3M26.
Posted on Sep 17, 2008
  • 68 Answers
SOURCE: GE Profile makes clunking sound and periodically quits working
listen to your repair man
Posted on May 02, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Won't stay cold...
If the compressor is shot, then there is not any reason to keep it. The parts and labor will cost you as much as a new fridge and then at that is not guarnteed to work correctly after the job is finished, or how long it will last afterwards
Posted on May 27, 2009
Hi I also would like to know where woul the heating lement b located i the whirlpool dryer thats about 10 years old. Thx
They are either in the rear of the dryer behind the back panel or in the front of the dryer depending on what model you have.
Nov 10, 2015 | Whirlpool Dryers
How much is this Model worth? 6 years old?
Worth Not much as life expectancy on most new appliance is 4 years or less ,it called plan obsolescence or made to fail as economy is based on consumerism not quality
Aug 20, 2014 | Whirlpool Duet Front Loading Dryer Rack...
I need an answer please. why does my dryer tumbles but there is not heat. dryer 10 years old, should i replace or repair? thank you!
There is a common part that goes out after a decade on most dryers and it is called a "solenoid" which activates the heating function and turns heat on and off according to the setting you've commanded. The thermostat controls the degree and temp of heat, but when/if the solenoid fails ($20 part) there is NO HEAT that occurs. Dryers are very simple devices, hardly need replacing EVER, but with a repairman's help you should not have to spend much to get your machine working for another 10 years! Call a local repairman for the good news and have him fix it for you.
Oct 08, 2010 | Dryers
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Dryer works but there is no heat in cycles, just plain air drying, do not know how to get hot air, it is an 10 year old kenmore gas dryer, has a dial for time of cycle, can not turn dial to get warm or hot...
I think you will need a repairman to fix this. The gas valve coils may be bad if the igniter radiates but then shuts off before the gas ignites. A repairman can also look at the radiant heat sensor nearby the igniter and replace it if it is bad. He should inspect fuses and circuit breakers and the heating element for continuity, using a device called an OHM Meter. I don't think this is a do it yourself repair job.
Feb 03, 2010 | Kenmore Dryers
Model LE/GQ8858J no heat in dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
tyt
Aug 02, 2009 | Whirlpool LGR5636L Gas Dryer
No Heat on a whirlpool dryer. 14 years old.drum turns,timer moves,getting gas to valve,tapped solenoids-no change.burner not lighting. thanks for any info
if ignitor not coming on could be flame sensor mounted on side of burner housing or ignitor ..if ignitor glowing but burner no lighting replace both solenoids bad connections interally on solenoids..also if ignitor not glowing possible small white thermal fuse open.. sensor and fuse can be jumped across to confirm ..
Dec 22, 2008 | Dryers
Gas dryer problem
I am getting water in my vent hose. What could cause this.
Dec 13, 2008 | Roper RGX4634KQ Gas Dryer
www.marcone.com
www.partstoday.com
Mar 17, 2008 | GE DCSR483EA Electric Dryer
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
