Question about Simer 1/6 Hp Submersible Utility Pump
I have a simer submersible utility pump model 2325-02 The pump was mistakenly opened on the wrong end, exposing and spilling the oil within. Is the pump still usable? I don't know how much oil was really lost and I don't know what grade of oil was in there. If the seal was broken (gasket keeping oil in and separated from any water) will I be able to get it back just so. Worried....I just don't know. Mike
3 Suggested Answers
VtToolMan
  • 704 Answers
SOURCE: what kind of is used in a simer submersible
The Simer brand of submersible dewatering pumps rely on being fully submersed in water for proper cooling and for the seals to remain water tight and effective.
According to the manufacturer, there is no oil used in the pump, other than a very small amount that was used in assembling the pump at the factory, so you shouldn't oil the pump, but rather follow the recommendations as to making sure the pump is installed properly.
Here's the owners manual for your particular pump (Model #2300) so you can check the troubleshooting FAQ's and so you can also contact the manufacturer, should you need replacement parts or need to make a warranty claim, etc.
http://www.simerpumps.com/pdf/1000001370.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 17, 2009
housejess
  • 317 Answers
SOURCE: Simer submersible utility pump Model 2300-03 motor
take screws off the screen on the bottom of pump.....clean well
Posted on Nov 17, 2009
I have a Simer 2305 and the pump will run but does not when the water is low?
Pumps such as the Simer 2305 do not pump water totally down to ground level. They are designed so they do not suck up debris , sediment, etc, which can clog and ruin the pump. So if your pump leaves an inch or so of water, that is normal.
Mar 15, 2014 | Simer 2305 Geyser II 1-4 HP Submersible...
Brand new Simer pump Model 2330-03 runs 10 seconds shuts off, turns back on, runs 10 seconds shuts off, etc., etc. Why is this happening?
Sounds like a faulty switch on the float. Try to hold the switch up by hand and see if it stays running, if so you may need to lube the switch. If not then it sounds like a manufacturer defect and needs to be returned.
May 07, 2011 | Simer 1/6 Hp Submersible Utility Pump
Model 2305 pump. Housing is cracked. Can I buy
since the pumps cost is only about $40 i doubt that they make after market housings for it and i could not find any
Sep 25, 2009 | Simer 1/6 Hp Submersible Utility Pump
What kind of is used in a simer submersible
Sep 17, 2009 | Simer Plumbing
Submersible utility pump needs oil,what kind should I use in it.
What looks like 'oil' coming out of your pump is actually water! It has leaked and is fully contaminated. The seal for the pump must have leaked and it filled up. Take the 'big screw' back out and drain it and let it dry for a couple days. Then use some silicone as a gasket and put it back together. You may run again! It will probably fail sooner rather than later with a bad bearings from the water damage. That's what gave it the oily appearance.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 26, 2009 | Craftsman Professional 1/4 Hp Submersible...
I need a power cord for my 1500 gph 1/6 HP Flotec submersible pump. where can I get one? Cat # u2 Serial # 50833
Get ready for sticker shock:
http://www.abtecparts.com/simer_cords.htm
Simer and Flotec parts are interchangable.
Feb 17, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Simer 1/6 Hp Submersible Utility Pump Logo
108 people viewed this question
Top Simer Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Simer Garden Expert? Answer questions, earn points and help others
