Question about Sony BRAVIA KDL-40S2010 40 in. LCD Television
Hdmi port not working.
How do you fix a hdmi port that stopped working?
3 Suggested Answers
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
HDMI port used to connect to TV suddenly stopped working it was working perfectly before.. Any ideas? TYI
Are you sure it's the port and not the cable? Check it using another HDMI cable before going any further. Most TVs have more than one HDMI port. If you pulled the cable out or was rough in inserting the cable, you might have damaged the port. If there's another port, switch to that one and just reset the info on your TV to use that port instead of the other...but I'd check the cable first...that's the easy fix.
Apr 17, 2017 | Televison & Video
Viera TH-L39E5K. Why isn't HDMI connection working?
Try a different HDMI cable first into all ports. Try every HDMI cable you have. Then try a different component into TV HDMI ports. If you are using the receiver to switch inputs, try running HDMI cable straight into TV. HDMI is very finicky. Some cables won't work or stop working for no apparent reason.
Nov 02, 2015 | Panasonic Televison & Video
How do I fix an HDMI input that has stopped working
This sometimes happens on my Samsung tv. With the tv switched on try unplugging the tv from the mains supply and leave for 3 minutes then plug back in and try. I hope this helps.
Nov 16, 2013 | Sony Grand WEGA KDF-55XS955 55" Rear...
HDMI Ports on Toshiba Flat Screen TV stopped working
That's highly unlikely!!! More likely is that the cable is having problems or that someone mistakenly changed the picture i the TV from HDMI to regular reception. If the HDMI ports are changed to regular TV reception they don't see the HDMI ports only the regular video ports!
Jan 01, 2013 | Televison & Video
Hdmi panasonic ports suddeldy stop to work
Bump... I'd like to learn the fix also.
Hdmi Splitter
Aug 06, 2012 | Televison & Video
One of the hdmi ports just stop working on my tv
HDMI ports are very fragile the solder can go bad on the pins, and it is not so easy to re-solder the pins, to fix the problem you have to replace the whole board. You can gently giggle the port and see if you can get a picture.
www.aaatvservice.com
Apr 21, 2012 | Samsung Televison & Video
Hdmi port stopped working on sony bravia KDL-32L4000, when I connect my ps3 or direct tv trhough hdmi cables I will just get a blank screen that will say no signal.
I have a Sony Bravia model KDL-46s5100 that had the same problem. All HDMI ports stopped working. I don't know why this works but unplug the TV for about 30 sec, then plug it back in and hold down the power button on the tv for 10 seconds. Like I said I don't know why this works but it worked for me. Good luck.
Oct 07, 2009 | Sony Televison & Video
HDMI PORT STOPPED WORKING!!
the best option here is connect via a standard PS2 avi cable or componet cable until your tech guy comes out!
Apr 30, 2009 | Televison & Video
No Sound
possibly the sound part of the DVD player went out it happens all the time but to get it fixed you have to take it to a repair shop. Hope this helps =)
Feb 25, 2008 | Zenith DVB712
Sony BRAVIA KDL-40S2010 40 in. LCD Television Logo
134 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
