Question about Nuvico NVJV-4000N Video Recorder
How can I convert the Nuvico NVJV 8000 from NTSC toPAL?
How can I convert the Nuvico NVJV 8000 from NTSC to PAL?
I have the DV3-8000; the service menu can be accessed by holding down keys 1 and 3 simultaneously; there is an option to select either NTSC or PAL; my GUESS is select PAL; don't know if there is more to it than that, but this is a start . . .
Posted on Sep 09, 2010
My tv has NTSC system but our local transmission is pal system. so picture is black & white and has no audio
hi,
It seems you are going to have to buy a PAL to NTSC converter box, check out the following info i got from eHow.
NTSC, or National Television System Committee, is the system used to broadcast television that is still analog in North and South America and parts of Asia. PAL, or Phase Alternate Line, is one of the other two analog broadcast systems used in much of the rest of the world. If you are in an area that can pick up both, but your television is made to receive only one of them, you can buy an PAL-to-NTSC converter that will allow the correct input to your TV.
Purchase a PAL-NTSC converter. Most mid-range converters will convert back and forth between either system, so if you're not sure which system your television picks up, you can buy one of the dual converters. See the References section for an example of a mid-range converter. When you purchase, choose either 110V or 220V power source, and which country you are ordering from (you will need the appropriate power cord adapter for your country).
Plug the included connector cord from the "Input" (or possibly "Antennae") jack on the back of your television to the "Output" on the converter. Also, plug the power adapter into a floor jack or other power supply.
Move the Input switch to PAL and the Output switch to NTSC on the converter if it is a dual converter. This will enable you to receive PAL TV signals and convert them for your NTSC TV.
Read more: http://www.ehow.com/how_6281541_convert-pal-ntsc-tv.html#ixzz2tSt08zQt
Feb 16, 2014 | LG 32LG30 32 in. LCD HDTV
NTSC to PAL question
yes system conversion is you need just change the crystals! buy a palsecam crystal then replace the old crystal.
Dec 24, 2007 | Hitachi M2 Digital Camera
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
How do i change my channel tuner from NTSC to PAL?
you need to get a converter that takes pal and converts it to ntsc.
Apr 16, 2012 | Sanyo DP50747 50 in. Plasma TV
Nuvico nvxg16000 password reset
wohs this password for nuvico
adminsitetar
Aug 11, 2010 | Nuvico NVJV-4000N Video Recorder
I notice that there is lan or rj45 connection in the rear of my Nvjv 4000.Does this in any way indicate that the stored video can be view remotly or over the internet?
Yes it does. and you can control up to 99 dvr's and control the settings as well. This model also has a self reconfig feature every time the ip address changes so you don't have to get a static ip address.
Sep 10, 2009 | Nuvico NVJV-4000N Video Recorder
Convert ntsc to pal for sony bravia tv
While a modern PAL TV can display NTSC sources (namely DVD players and PAL VHS players that support pseudo-NTSC), an NTSC TV can not display a PAL source, unless it's an expensive multi-standard TV. Sorry pal, bad choice.
Mar 30, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Converting NTSC home Video tapes to Pal DVD or NTSC DVD
You need either an NTSC DVD recorder (keep in mind that the US has 110 voltage, while Australia does not), or a computer card that supports NTSC. Some video capture cards support both NTSC and PAL (often switchable). Choose good quality, and pay attention to video/sound sync - some bad quality cards loose sync. Once the tapes are transferred to DVD - and keep it native NTSC all the way, they can be played on virtually any PAL DVD player/TV combo. With an NTSC source, it's best NOT to convert to PAL, while with a PAL source in the US, you'd need to convert to NTSC or only show the DVD on a computer (where NTSC/PAL doesn't matter).
Feb 19, 2009 | Panasonic DMR-ES35VS
Ntsc to Pal How to convert ntsc tuner to pal tuner
you will need to buy a converter. like this one
http://sewelldirect.com/MayFlash-NTSC-to-Pal-Converter.asp
Apr 15, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Nuvico NVJV-4000N Video Recorder Logo
421 people viewed this question
Top Nuvico Televison & Video Experts
Marvin
Marvin
Are you a Nuvico Televison and Video Expert? Answer questions, earn points and help others
