Question about Gateway GT4022 PC Desktop
I have a gateway laptop (no cd, preloaded) Keep
I have a gateway laptop (no cd, preloaded) Keep getting error after restore / recovery of NTLDR is compressed! HELP!
    Novelist:
  • 145 Answers
Your missing the file from the nt detect application on the C: drive You will need to obtain a good copy of windows or find an OS that you can work around it with. I would try using Ubuntu as a live session disk and replacing the corrupted nt detection files from a disk or website.
this might help you
http://www.quickonlinetips.com/archives/2005/12/ntldr-is-missing-press-any-key-to-restart/
Posted on Aug 01, 2010
I have a gateway mx6920 and is trying to do a factory restore. when i go to f11 the recovery start but at the end it show system restore envionment is incomplete. then it ask for a cd
This error is caused when your restore files are corrupt. If you have the system cd that came with your pc, you can restore your pc and the restore drive. If you do not have the cd, check Gateway's support website for restore ISO file for your model of pc.
Good Luck
C2Solutions
Feb 10, 2011 | Gateway MX6920 Notebook
Ntldr is compressed
An NTLDR is compressed error is pretty easy to fix(much better then NTLDR is missing errors!).
First you need to boot to the recovery console.
To boot to the recovery console follow these steps:
1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. Now you should be at the comman prompt and ready to repair the ntldr file!
Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here:
cd \
attrib -c ntldr
exit
Your computer should now reboot, and everything "should" work!
Feb 25, 2010 | Microsoft Windows XP Home Edition
Ntldr is missing press clt alt del to restart
The NTLDR and Ntdetect.com files are important system files that are used by your computer to start the Windows XP operating system. These files can become damaged, corrupted or deleted for a number of reasons and are usually brought to your attention by the "NTLDR is Missing" error message.
Follow these easy steps to restore the damaged/corrupted or missing NTLDR and Ntdetect.com files from the Windows XP CD using the Recovery Console.
Time Required: Restoring the NTLDR and Ntdetect.com files from the Windows XP CD usually takes less than 15 minutes
Here's How:
Boot your system  using a Windows XP CD, press any key when the windows display "press any key to boot from CD"and wait for some time, select "r" option to go to recovery console. it will ask you for administrator password too.
When you reach the command prompt type the following two commands, pressing Enter after each one:
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
That's it.
Jan 22, 2010 | Acer Aspire 5315 Notebook
Black screen NTDLR Press any key to restart
Are you saying it came with a recovery disk that you dont have anymore. If thats the case you may need to aquire this from acer. If you go to their web site you can usually find a way to order this disc for your machine.
Find someone who has an xp disc and use it to go to recovery console then restore MBR files. NTLDR is the error meaning your master boot record has been damaged.
Char S.
May 27, 2009 | Acer Aspire 5102WLMi Notebook
Recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Jan 08, 2009 | Acer Aspire 3000 Notebook
Acer aspire 3680
You need to boot with your windows vista cd and select repair install. This will reinstall the windows files, including the ntldr file, leaving your data intact. Make sure you only do the repair install, if you do the full install, it may wipe your data.
Thanks and please take a moment to rate as fixya.
Nov 07, 2008 | Acer Aspire 3680 Laptop
My dell d600
NTLDR or NTDETECT Is Missing or Corrupt Error Message
Table of Contents secondary.gif Start the Recovery Console secondary.gif Repair the Missing NTLDR or NTDETECT File » Start the Recovery Console
  1. Insert the Windows XP CD into the CD or DVD drive.
  2. Restart the computer.
  3. While the computer is starting, repeatedly press F12 every 3 seconds to access the one-time boot menu.
  4. When the one-time boot menu appears, press the Down Arrow to highlight the CD-ROM option that appears, which is one of the following options: Onboard CD-ROM Drive or Onboard USB CD-ROM Drive.
  5. Press Enter.
  6. When the computer boots to the CD-ROM drive, press R to enter the Recovery Console.
» Repair the Missing NTLDR or NTDETECT File
  1. Boot the system to the Windows XP Recovery Console.
  2. Type map, and press <Enter>. Make note of the drive letter assigned to the optical (DVD or CD-ROM) drive.
  3. Type copy x:\i386\ntldr c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  4. Type copy x:\i386\ntdetect.com c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  5. If you are prompted to overwrite the file, type y, and press <Enter>.
  6. Type exit and press <Enter>.
  7. As the computer restarts, remove the Windows XP CD.
The files have been restored and the error message should be fixed.
You can check this website for further details.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=B93824605BF646F98FDFACA51E3A9B55&journalid=4F6F8BC06C3B5014E040AE0AB5E121D2&Query=TlRMRFIraXMrbWlzc2luZw==&SystemID=LAT_PNT_PM_D600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Pls let me know asap if we did resolve it.
Dont forget to rate me Fixya....
Cheers.
Jun 15, 2008 | Dell Latitude D600 Notebook
Computer crashed and will not restore.
if u tried installing windows from a CD onto the HDD and it still says missing ntldr. seems like a Bad hard-drive.
you can restart by pressing control-alt-delete.
then, try booting from windows CD and repairing the windows installation. if it gives u file copy errors.then, it is a HDD failure. get a new HDD.
Mar 30, 2008 | Acer Aspire 5100 Notebook
Notebook will not boot
If I understand what your problem is...
I had the same problem, it was a caused by bad Windows XP install CD.
Call Gateway and explain the situation, you may need to have a magnifying glass handy to read the tiny engraved lettering in the center of the CD disk.
Have your 'Product Key' available.
If you have some kind of sales receipt, or other "Proof of Purchase" have it handy too.
You will need to tell them, you do not have the program installed on other computers.
They can send you another disk.
This method will only work if you have a legal copy of the program.
Oct 31, 2007 | Gateway MX6421 Notebook
Gateway GT4022 PC Desktop Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
