Question about Philips Televison & Video
I just dug up my Phillips Unversal Remote Control for TV, VCR,DVD, etc, however I no longer have its owners manual to dial up the code needed to operate my Sanyo TV. Will you please provide the 4 digit code for Sanyo TVs?
    President:
  • 1,932 Answers
Please go to below website you can get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.I just dug up my Phillips Unversal Remote Control - ff32c84.jpg
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
Posted on Jul 29, 2010
I have a g e universal remote and i dont have a code for it to work on a phillips tv
Good day!
This are the 3 digit codes for your Phillips TV. 003, 004, 006, 008, 062, 068, 069, 074, 075, 076, 086, 087, 089, 133,
This are the 4 digit codes for your Phillips TV. 0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
How to enter codes manually:
  1. 899 Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
  2. Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
  3. Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
  4. Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
  5. Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
I hope this information will be helpful.Thank you and good luck.
Apr 23, 2011 | Universal Remote Control GE174Universal...
Need remote control code
Hello
Three digit universal remote control code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote control codes for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Four digit unversal remote control code for Panasonic TV/DVD/VCR combo is
0437
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR/DVD. Otherwise just the one code operates both the TV and the VCR/DVD.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Dec 02, 2010 | Panasonic PV-DM2792 Triple Play 27 in....
Need unversal tv remote GE, for sanyo tv...
try walmart / bestbuy / jandr.com or even duane reade for universal the codes for sanyo is in the booklet that come with the remote...look at the type 3 to 6 (depend on how many items you want to control w/ remote) tv/dvd/vcr/cable box etc
May 20, 2010 | Sanyo DS24425 24" TV
Can't get my Phillips universal remote to program my tv controls on my sv2000 t.v/dvd combo.
If you already tried the tv codes for your make of tv, the manufacturer suggests using the dvd codes for your same tv make sometimes they use the dvd codes to activate or control the tv on some of those tv/dvd combos. If all this fails you can always use the code search procedure described in your remote's manual, but you need to be patient because this procedure will scan thru all the programmed codes(vcr,dvd,sat,cabl etc.) one at the time.
Jan 16, 2010 | Philips Universal PH301S Remote Control
Instructions on how to program RCA universal remote control
This link is a .pdf of the manual with directions on how to program the remote as well as all of the codes for various electronic brands for all equipment (DVD, TV, VCR, etc.):
http://www.lexrixa.com/vcr%20codes.pdf
Jun 20, 2009 | RCA Universal Remote Control
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a panasonic omnivision vcr/tv combo and i had to buy a universal remote; i have an RCA rcr312w universal remote, but i need the code in order to program the television; what is the code?
I have the same tv/vcr combo and according to my Advent unversal remote chart Panasonic code =
one of : 1003, 1054, 1062, 1109, 1170 or 1248
According to my Phillips universal remote chart = 416, 937
Hope this can help you
Dec 22, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Codes to program Innovage Products Jumbo Universtal Remote
Innovage Jumbo remote codes for RCA TV; 000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191,194.
Pansonic DVD; 175.
Pansonic VCR; 021, 060, 115, 125, 138, 148, 149.
Philips DVD; 173, 183, 198.
Bell ExpressVu; 168, 187, 194.
Dec 18, 2008 | Televison & Video
Televison & Video Logo
110 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
