Question about Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat won't connect to computer.
My Gigabeat won't connect with my computer.. Anything I can do?
  • 3 Answers
I was just having this problem after I installed a new operating system on my computer. I finally downloaded the full setup (updated as of march 2009 on Toshiba's website)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/pubLogin.jsp?next_page=pubProfile.jsp&next_page_anchor=supportUpdates
Click on product updates towards the top.
I downloaded and ran the full setup instead of the standard one I had on my computer previously. Also, I don't know if you have a similar problem, but eventually I was able to connect to the gigabeat room, but when I put it in the windows media player mode, my computer didn't detect anything. For that, I had to right click on My Computer, Manage, and then go under Device Manager (left). On the right, you'll see a list in which you'll find the toshiba gigabeat. If it has a yellow ? or ! then go ahead and right click on it and try to have windows detect the driver itself. That solved the second issue for me, and my computer was able to install the driver itself and now my gigabeat is at least detected properly and connecting to my computer.
My current issue is different now where 15 GB of my music is unplayable due to some library updating failure :(
Anyway, hope the earlier part solved your problem.
Also, make sure when you run the update firmware, you follow the instructions correctly. Good luck.
Posted on Sep 02, 2010
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat-U MP3 Player suffering "USB ERROR #203"
try reinstalling any software that come with it.
try a different usb cable.
try different usb ports.
Jun 28, 2009 | Toshiba Gigabeat MEG201 MP3 Player
4yr old gigabeat 30gig won"t connect to PC
Try re-installing windows media player 10. It did the trick for me.
Feb 26, 2009 | Toshiba Gigabeat S30 MP3 Player
Vista recognises Gigabeat F40 as a hard drive and not an Mp3
hi had the same problem with mine, you must use the dock and have the connections setting set to media player it will sync then
Dec 05, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat S
im ahving an extremely simmilat problem but my gigabeat is connecting diisconecting (repeat) and my computer is not doing anything
Apr 16, 2008 | Toshiba gigabeat S MP3 Player
Computer does not recognize Gigabeat Device
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Won' do nothing
http://linuxphile.org/node/41 Download http://rapidshare.com/files/25382872/GigabeatSRecover.rar.html and connect your gigabeat to the computer. The portable media center will install.
Sep 14, 2007 | Toshiba gigabeat S MP3 Player
Toshiba Gigabeat MEGF40S MP3 Player Logo
454 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
