Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Where is the water control valve? and what am I
GE Profile dishwasher is running & heating but without water. I checked the water tube and there's no blockage. Yesterday I was advised to check the water control valve. Where is the water control valve, and what am I looking for when I check it? Could I have a bad water pump?
  • 11,896 Answers
Yes, the water control valve is likely your problem. Where the external hose attach to the internal hoses, there is the water vales in between them. The hoses screws right into the water control valves. The valves are likely not opening. You can test power to the valves with a voltmeter. If there is power on the fill cycle but no water, then valves are bad.
You can view parts and diagrams at partselect . com
Posted on Jul 28, 2010
  • 6 more comments
  • jim_mcewan Jul 28, 2010
    Would the valve that you are referring to be the water inlet valve, part #744 on partselect.com ?
  • Nate Stansfield
    Nate Stansfield Jul 28, 2010
    Yep that's it.
    I'm looking at the diagram on partselect.com, and where the wter inlet valve is located is not visible to me when I look in my dishwasher . . . . do I have to dismantle something to get to it?
  • Nate Stansfield
    Disconnect
    the power source to your dishwasher before you conduct this or any
    other repair. Either unplug the unit from the wall outlet, remove the
    appropriate fuse from the fuse box, or flip the appropriate breaker in
    the
    circuit breaker panel.
    Locate your dishwasher's water inlet valve. It should be located behind the lower kickplate panel
    in either the right or left corner. There will likely be two screws
    either on the top of the panel, or on its bottom. Remove these two
    screws, and then remove the kickplate. On some dishwasher models, the
    door has to be opened in order to gain access to, and remove the
    kickplate's screws. Close the door before you remove the kickplate
    panel.
    You will be able to identify the water inlet valve
    by the hoses that connect to it. There will be one hose feeding water
    from the house to the water valve, and another hose leading from the
    water valve that carries water away. Now is a good time to inspect your
    dishwasher's hoses, to make sure they aren't responsible for any water
    flow problems. Make sure the hoses are securely connected to the valve.
    Also check to make sure there are not kinks in the hoses.Turn off your
    dishwasher's water supply so that you can remove the hose attached to
    the water valve. The water supply turn-off is located beneath your sink.
    There will be a knob to turn or a lever to press down on.
    Alternatively, you can turn off the main water supply to your house at
    the main valve.
    Place a container below the hose to catch the water that
    falls out when you disconnect it. The hose that brings water to the
    valve will most likely screw in place like a garden hose. The hose that
    carries water away from the valve is probably held in place with a
    clamp.
    There will be two wires connected to the water inlet
    valve. If your dishwasher's water inlet valve has two solenoids, then
    there will be four wires. Label the wires so that you will be able to
    correctly reconnect them later. The wires are connected using slip-on
    connectors. Grasp the connectors and pull on them firmly in order to
    disconnect the wires from the valve's terminals. Do not pull on the
    wires themselves. You may want to use a pair of needle nosed pliers to
    help you.
    The valve itself will be secured to the dishwasher
    using at least two screws, but maybe more. Remove all the screws you
    find that hold the valve in place. Now you can remove the valve as well.
    Install your new water inlet valve in the same
    location where you just removed the old one. Secure it in place using
    the screws removed from the old valve. Reconnect the wires and hoses.
    Replace the lower kickplate panel and restore power to your dishwasher.
  • jim_mcewan Jul 30, 2010
    Thank you for this detail on getting to the valve. Once I get to it, how can I tell if it is indeed the problem? Will it be stuck in the closed position ? Or do I just replace it and then try running the dishwasher to see if the valve was the problem, and go from there . . . . .
  • Nate Stansfield
    Nate Stansfield Jul 30, 2010
    You can see if the valve is closed.
    You can also test the valve itself by removing the wires, place an ohmmeter on both connections of the valve and see if you get a good strong reading, If not, it is bad. You can also use a voltmeter and test the wires to the valve and see if there is power, if no power, than the valves are good and you could have a bad cycle switch or possible control panel issue.
  • jim_mcewan Aug 02, 2010
    Before I dismantle to get to the valve, I'd like to try re-setting the control panel to make sure it's not something simple. If I turn the circuit breaker to the dishwasher off and then on again, does that reset the control panel? If not how do I do that?
  • Nate Stansfield
    Nate Stansfield Aug 03, 2010
    You will need to leave the power breaker off for about 15 minutes. If you have a cancel, stop, or pause button, press and hold it for 10 full seconds with the machine breaker off.
The clean light keeps blinking and won't run new cycle
Whirlpool & Kitchen-Aid
Tall Tub Dishwashers
PROBLEM: STOPPED RUNNING, WILL NOT START AND CLEAN LED BLINKS 7 TIMES, THEN REPEATS (WATER HEATING FAULT)
Control is programmed to stop running and not allow any further
cycles if it detects a water heating problem (no temperature
increase detected in heated Main Wash cycle or in 3 consecutive
cycles on the latest software version). Control blinks the Clean
LED 7 times repeatedly and disables the Start/Resume key until
cleared.
Running Diagnostics clears the control and allows it
to operate again. The water heating condition
must be corrected or the control will stop
running again. See potential causes below.
Check If…
Heater circuit problem:
♦ Open heater.
♦ Wire disconnected, open connection or component
in heater circuit.
♦ Faulty heater drive circuit on control.
Then…
1. Check operation of heater in Diagnostics cycle.
2. Unplug dishwasher or disconnect power.
3. Check resistance of heater and all components
and connections in the water heating circuit or heat
dry circuit.
Door switch not making contact consistently:
♦ Misaligned door latch assembly (which can be
aggravated by high door closure force keeping
strike plate from fully seating).
♦ Faulty door switch (high resistance).
♦ Loose or missing installation anchor screws,
causing tank to shift in cut-out.
NOTE: Neutral switch on plastic tub models is only in series with
the heater; other loads are not affected.
1. Unplug dishwasher or disconnect power.
2. Measure resistance of door switch contacts while
checking mechanical operation of latch assembly.
Confirm switches not loose from assembly. Check
strike plate and door closure.
Wash pump not pumping water past the heater efficiently.
• Foreign object in pump
• Excessive foaming
• Clogged pump screen or broken chopper screen
• Loose electrical connection in motor circuit
See Tech Sheet “WASH PUMP WILL NOT PUMP”.
Lack of water to heat. (Unit not filling properly)
• Insufficient water supply pressure
• Fill valve screen blocked or valve not opening fully
• Loose electrical connection on Fill Valve.
• Float switch obstructed or functioning abnormally
See Tech Sheet “WILL NOT FILL OR LOW
WATER”.
Diagnostic Key Dance:
Heat Dry - Normal - Heat Dry - Normal or
High Temp - Air Dry - High Temp - Air Dry
HOPE THIS HELP
Jan 24, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwasher runs through cycle but no water.
make sure water is on ,if water is on and still no water in d/w then check water control valve
Nov 26, 2009 | GE 24 in. Profile PDW7800 Built-in...
When I start the dishwasher, looks like water is not coming
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drain valve
Oct 19, 2009 | GE 24 in. Profile PDW7800 Built-in...
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher will not fill up with water
did you chek the level micro switch thats in serie with the intlet valve
Jun 18, 2009 | GE 24 in. Profile PDW7800 Built-in...
Machine runs full cycle without water!
The most common reason for this problem is the inlet valve (Solinoid valve) has failed and does not open when the DW timer tells it to before each wash and rinse cycle.
That valve is just inside the place where the hot water supply hose connects to the dishwasher.
There can be other causes but this is by far the most common reason.
Good Luck!
Apr 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
PDW7880J10SS: No water
First check to be sure that the valve that controls water coming from the hot water supply is turned on. This may be right under the kitchen sink. If it is turned off, just turn it back on and u should be set.
However, if you have water coming to the dishwasher but no water in the dishwasher it has to be one of two items:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Feb 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Sep 02, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
