I washed rugs yesterday Door is locked and I am unable to open it.
  • Washing Mach... Master
  • 8,220 Answers
Maybe some of them rug strings got down in the pump filter and stopped it upI washed rugs yesterday Door is locked and I am - 0f02815.jpgf9f10e0.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 28, 2010
My washer dryer was on baby cycle wash and although the green light has come on to indicate it has finished, red lock key is also on and I am unable to open the door.
Martha, Try running another cycle, for some reason I think machine is sensing it still has water in it. If after running another cycle dose'nt do it, check links below to see (2nd link) how to open door manually with out damaging machine. press the helpful button
How to fix washing machine door lock in Hotpoint washing machine
Opening locked washing machine door
Feb 10, 2016 | Hotpoint Aquarius WD640 Front Load...
Kenmore he2t
fluff may have blocked the filter or jammed the drain pump. you need to check these
May 07, 2014 | Washing Machines
The door is locked, there is a rug inside. Machine was beeping but I can't open the door. How can I unlock the door?
Unplug the washer. Remove the bottom front panel. Reach upward, inside the panel, toward the door latch until you feel a teardrop-shaped tab. Pull that tab downward until you hear the door lock release the latch.
Good luck.
Mar 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Was washing my kitchen rug and on the rinse and spin cycle I got an error message, perhaps because the rug was too heavy when wet to spin. I took rug out, water standing in washer, tried to clear error and...
With the Door Lock display on (which is what the red key indicates), are you able to open and close the door?
If so, you probably have a defective door lock assembly. Try unplugging your machine for a couple of minutes and plug it back in to see if it resets itself.
Oct 10, 2009 | LG WM-2277HW Front Load Washer
Door locked
ome washing machines have a cord fixed behind the filter flap door that will open the door if pulled. Is the machine full of water, if so disconect the waste pipe and drain the water into a bucket, this may let the door open if switched back on.
Last resort use a thin flat bladed screwdriver, a blunt ended one of possible to get round the seal by the lock, you may be able to release the door
Jun 01, 2009 | Kenmore Elite 45986 Front Load Washer
Door wont open, ITS LOCKED
HI, this is basically a door lock mechanism failure. the control is unable to communicate with the door lock mech. you will need to replace the door lock mech in this case. it has failed.
May 29, 2009 | Kenmore Washing Machines
Unable to lock door!
Step 1 go to http://www.frigidare.com
Step 2 click on CUSTOMER SERVICE on top of page
Step 3 go to PRODUCT MANUALS and click on DOWNLOADS
Step 4 type in MODEL NUMBER and click on search
Step 5 your error code information is in the TECH DATA file there you can perform a full system check PLEASE READ ALL WARNINGS POSTED
Step 6 save all PDF files to a new folder name it FRIGIDARE for easy availbility for printing and viewing.
Thank you and good luck.
Jun 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
