How do i set the timing the air filter is blowing instead of sucking
    Brigadier General:
  • 4,044 Answers
The Timing in what? It sounds like your 180 degrees out of time. But this posted under the "Web" entries and not in vehicles and you didn't identify the vehicle. You need to go to Auto Zone or another Similar Auto Parts store and purchase the Haynes repair manual on your vehicle to do this repair.
Posted on Jul 28, 2010
Shop Vac MAC 12-200D my shop vac is blowing air instead of sucking air. How do I fix it
this might sound silly but have you got the pipe in the blowing end instead of the sucking end hope this helps
Oct 09, 2016 | Shop Vac Vacuums
Air and gas blowing out the intake
sounds like timing chain/belt jumped time.
Dec 16, 2013 | 1991 Toyota Camry
I recently purchased a house with a Filter Queen Central cleaning system model FQ-7500. My problem is that instead of sucking air it blows the air out. How do I reverse the air flow?
Never seen this model but it is on of two things,the hose is hooked up wrong or the motor is either switched in reverse or the motor has been reversed with wire leads
Feb 17, 2011 | Filter Queen Majestic Canister Vacuum
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
My honda gx340 generator will not run on high speed correctly it seems to be blowing back throu the air filter not sucking in air? it starts on the first pull every time but will not generate any power on...
blowing back through the air filter would suggest an inlet valve problem you will need to remove the cylinder head a inspect it. if it not damaged then it will probably need groinding in
Jul 10, 2009 | Electrical Supplies
95 xr7 wont start after head gasket up replacement,got spark got fuel set timing. only thing is intake blows instead of sucks? is that normal? what could the problem be?
Do you mean the air intake? If your air intake blows and the motor doesn't run it may mean your valve timing is wrong. How did you set your valve timing after you took off the head? If you weren't careful you may have set the timing for number 1 cylinder on its exhaust stroke and not its power stroke. This will put your timing 360 degrees out.
Incorrect valve timing may produce the effect that the engine pumps air out of its intake when it is cranked.
Oct 10, 2008 | Mercury Cougar Cars & Trucks
Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Jan 07, 2008 | Vacuums
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Jan 05, 2008 | Vacuums
HELP!!!!!
The hose is probably clogged. It is supposed to blow out at the filter. It filters the exhaust air so you don't get dust back into the air.
Oct 16, 2006 | Regina RG3100 Vacuum
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
