Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water dripping insie the fridge
Water has been dripping inside the fridge and it gathers under the crispers.
Please advise
    President:
  • 1,099 Answers
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
Posted on Jul 28, 2010
Water seems to be gathering and then dripping from under the control panel which is situated in the main fridge, on the back wall, behind the top shelf.
sounds like a bad plugged evaporator drain plug? which then freezes up and moister - water/ ice build up takes place in fridge
Mar 08, 2015 | Refrigerators
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
WHY IS THERE WATER LEAKING INSIDE THE REFRIGERATOR
generally water leaks on top mount freezer types when the defrost tube is plugged. The automatic defrost system works to keep humidity from blocking air flow across the evaporator(behind the back freezer panel) If it can not drain you will see it as water dripping from the top of the fridge section and water under the crispers.......Clean the drain tube under the evaporator of ice(poke a hole in evaporator and you are buying a fridge)........hope this helps
Jul 29, 2012 | KitchenAid Refrigerators
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water is not draining into pan. it is going inside fridge under
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Mar 17, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Water dripping from top of fridge then freezing under crisper's
HII Your drain line is plugged remove evaporator cover and get a hair dryer and remove all the ice built up on the drain line its a hole just below the evaporator..show here the hole is on the left side.Good
Jan 05, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Hi, I have a 12 year old F&P fridge, model C270 which is working fine but has leaked twice this week. The leak appears to be coming from the base of the fridge as there is water beneath the...
what might be happening is that the drain hole for condensate is blocked causing water to gather beneath the crisper. look for a channel under the evaporator (the icy cold part) and there should be a drain hole some where near check this is not blocked.
Dec 07, 2008 | Fisher and Paykel Refrigerators
Water Is accumulating at the bottom of my fridge....below the vegetable/fruit crispers. The fridge however contiues to keep things cold.
The automatic defroster is supposed to drip down a tube and deposit water into a tray underneath the refrigerator. If that tube becomes clogged with either ice or mold, water is supposed to drip down the back of the refrigerator and go under the crispers, but there is a drain under there that takes it to the tray under the refrigerator. That drain might get clogged with mold or food.
So my suggestion is, try to clear out the drains under the crispers. More difficult, remove the floor of the freezing compartment and clear out the drain there. If it is severely clogged with ice under there, you have a defrosting problem.
In this hot, muggy weather you are likely to get lots of condensation. Good luck.
Jun 13, 2008 | Whirlpool Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
259 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
