Question about Dell Computers & Internet
I have a dell Inspiron D530S computer with Windows Vista. I keep getting a alert that say's that I have Low disk Space on my Recovery D.How do I clean out this Recvery D program and restore it back to where it should be. I have followed instructions to clear it in the program, but the alert reappears. I must not be clearing t out . Please advise Thank you
    President:
  • 2,340 Answers
The alert is a notification that your Hard Disk(HDD) space is almost fill up. You should not remove or delete the "Recovery D Program"! , if you do not have any copy of Recovery CD, just in case of emegency if your PC/Laptop have any booting problems. Dell embedded the "Recovery D" because they do not give you any "Recovery Disk" in a CD/DVD form nowdays. On the safe side make a copy of the recovery disk.
Options you can do is to reduce you data on the HDD, by
1. You can uninstall programs you don't use.
2. Transfer your data to another external media
Alternatively you can upgrade your PC/Laptop with a bigger capacity HDD, and fresh install Windows on it.
Posted on Jul 28, 2010
Low disk space on recovery d
That is the recovery partition that holds the files to refresh the laptop to it's original state. If you are trying to save files to that partition, you aren't supposed to. If you aren't and explorer is showing low disk space and the computer is running fine, don't worry about it. The C: drive not having space is what will cause problems.
Feb 12, 2015 | Dell Inspiron 1521 Notebook
Dell inspiron 1720 vista admin password recovery?
If you are running Windows 7, if you type in the wrong password once, it normally says reset password... below the box for the password. Insert a removable disk (such as USB, floppy disk, etc.)
and follow the prompts.
Oct 25, 2013 | Computers & Internet
I forget my MY dell inspiron 1520 Laptop of vista basic OS's password and later on typing wrong password it also blcok the system and displays messag
Crack Dell Laptop Password
U can search the above words via search engine and get ideal suggestion from search results!
Then, there will be solutions supported:
Step 1. Access other PC which isn't locked, download the Windows Password Recovery Tool 3.0, install and run it.
Step 2. Burn a password reset disk. You can choose CD/DVD or USB.
Step 3. Connect the nearly created disk with the locked Dell laptop, config bios setting to make sure it boot from the password reset disk, reboot the computer.
Step 4. Choose the user that you forgot its password, click "reset" button to begin crack its password.
Step 5. A message box will pop up, just click "Yes", then the user's password will be cracked to blank.
Step 6. Disconnect the password reset disk, and restart Dell laptop. You will login Windows with a blank password.
Hope it helps you!
Nov 21, 2011 | Dell Inspiron 1520 Motherboard
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525 and when I let it sit idle for a time it freezes up and has t be rebooted. I ran a diagnostic on it and came up with the error code 0F00:075D. What does it mean and what can I...
We wish you a very Happy New Year.
Which is your operating system?
Below mentioned steps are for Vista,assuming your operating system is Vista.
Post back if it is not Vista.
Run it from the Command Prompt of Recovery Options if you have, or a Vista boot disk. You can
borrow a friends if needed as they are not copy protected or make a repair disk.
And/or Run the other diagnostic tools I listed.
You probably do have hard drive issues its only can they be repaired or not.
If you need to make repair disks - these help repair Windows not re-install.
How to Make a Bootable Disk in Vista
http://www.brighthub.com/computing/windows-platform/articles/7050.aspx
Download: Windows Vista 32 bit (x86) Recovery Disc and Windows 7
http://neosmart.net/blog/2008/download-windows-vista-x64-recovery-disc/
Download: Windows Vista x64 Recovery Disc and Windows 7
How to Make a Windows Vista Repair Disk If You Don't Have One
http://www.howtogeek.com/howto/windows-vista/how-to-make-a-windows-vista-repair-disk-if-you-dont-have-one/
Hope this helps.
Cheers!!!
Jan 02, 2011 | Dell Inspiron 1525 Laptop
I have a dell inspiron 6400 and every time i turn it on i get a blue screen and it say: a problem has ben detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT_VOLUME...
its called the blue screen of death and it could have been caused by something you installed recently or a hardware issue, have you tried booting your computer into safe-mode using the F8 key if you cannot boot into safe-mode without getting the same issue then you may have to format your hard drive
Jan 01, 2011 | Dell Inspiron 6400 Notebook
Running Vista, Pop up window,
Click computer, then right click on the D drive. Select properties and format the drive.
Jul 27, 2010 | Dell Inspiron 530 -Intel® Pentium®...
Low disk space
If you are using windows as your o/s; open the control panel, click on performance & maintenance, run a disk cleanup then defrag your drive. The recovery bar red means that the space allotted for recovery operations is very low. Hope this helps & please remember to rate my answer. Thanks.
Jan 26, 2009 | Dell Inspiron 530 Desktop Computer
Computers & Internet Logo
148 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
