Question about HP Compaq Presario SR2011WM PC Desktop
Can not use ctl alt del on computer - HP Compaq Presario SR2011WM PC Desktop
  • 148 Answers
This problem is caused by Viruses use a good anti virus and update it regularly....
Posted on Jul 28, 2010
Delete key . Does it work?
Usually the "delete" on macs key does the same as the "backspace" on Windows/pc's, which erases typing going backward. The "del" or Delete key on non-mac computers usually means it erases things forward. Also the classic "ctl + Alt + del" usually stops processing the current application or opens a window to control which programs are running/freezing.
Dec 08, 2013 | Kensington Computers & Internet
Ran out of disk space on my Vaio desktop PCV-RZ24G. 120 gig drive but c formatted to 19 gig. purchased a WD 250 gig and did a disk clone. installed in pc and at first power on it stops at no boot device...
This is what I disliked about the "Sony hard drive partitioning plan" - they don't give you all of the C partition and then you run out of space. Out of frustration, I formatted the entire hard drive so that no remnants of Sony was in it and installed a fresh copy of the operating system, used the product key from the original operating system, sticker (label) affixed on the case to active Windows again. I got the entire C partition all to myself! Since you cloned that hard drive, you still have the "Sony hard drive partitioning plan".
Dec 30, 2010 | Sony VAIO Digital Studio PCV-RZ24G PC...
Account has been temperiary down
Press controll +Alt+del together and say change password and use a new password should work in windows 7
if its windows xp pres twice the CTL+ALT+DEL and log in as user name Administrator password blank or administrator ok
thanks and regards
Dushyant
Dec 10, 2010 | Computers & Internet
Computer says disk drive error press ctl alt del
MX6440 PC Notebook have a problem of file dumping
  • computer says disk drive error press ctl alt del to restart
  • Reastore or Reaper the OS may fix the problem
  • Or you have to Reprogram your computer by formating the System software
Dec 01, 2010 | Gateway MX6440 Notebook
How do I get my computer restarted from a black screen when ctrl+alt+del does not work
Hold down the Ctl + Alt+Del keys together for about 15 seconds, this should put the system into a state that allows you to disconnect the power for about 3 minutes.
Plug the power back in and re-boot in "Safe Mode", this will flag up any errors and more than likely repair the system files as it starts up.
If still nothing listen for error codes when it is powered up, this will give a rough indication as to what is faulty, VGA, RAM, Sound card etc.
Was anything being changed or unplugged/plugged in just before it went wrong?
Hope this helps.
Nov 03, 2010 | Computers & Internet
I turn on my computer tower and a blue screen appears saying mountable volume and it keeps on re-booting. what can i do
Get into the bios screen by pressing f2 or ctl-alt &del or just the del key depending on your bios chip and see at the fiirst screen if your hard drive is visible....if not you must remove the old one and replace it.... or maybe reformat it and install your operating system again.
Jan 06, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
Laptop will not start,
looks as though your hard drive is u/s Try and see if it is visible in the bios pages, if not replace it. Bios being, when you switch on you press f2, or ctl-alt.del or just del key. This puts you into the BIOS which tells the computer what it can and cannot do. The 1st page should have your hard drive listed, if not then replace it.
Jan 05, 2010 | Advent Netbook
When I turn on the computer I only get a black screen with the message "BOOTMGR missing Press CTL ALT DEL" of course when you press CTL ALT DEL it just brings you back to the black screen with the same...
1. Put the Windows installation disc in the disc drive, and then start the computer. 2. Press a key when you are prompted. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. Click the operating system that you want to repair, and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type Bootrec /RebuildBcd , and then press ENTER. • If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type Yes . A confirmation message appears that indicates the entry was added successfully. • If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command. Bcdedit /export C:\BCD_Backup ren c:\boot\bcd bcd.old Bootrec /rebuildbcd 8. Restart the computer.
Oct 17, 2009 | Lenovo 3000 G530 Notebook
A disk read error occurred press ctl-alt-del to restart goes back 2 same scrn
Sounds like the hard drive has errors.
Boot to a windows XP cd.
Repair using the windows console.
at the repair console type:
chkdsk /R (hit enter)
Let that run, it takes a long time.
If it's able to repair the drive enough for operation it will.
If it cannot you will be forced to replace the hard drive.
HTH
Aaron
May 23, 2009 | IBM Aptiva E 2170 PC Desktop
Please help uninstall
Try starting in Safe Mode and then uninstall it.
(press F8 during boot).
Jan 24, 2009 | IBM Lotus SmartSuite for PC
HP Compaq Presario SR2011WM PC Desktop Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
