Question about Toastmaster Heating & Cooling
Teledyne Laars Cycyling Problem
I have a Teledyne-Laars JVT-100 Mini-therm combo, It seems to work normal when it first starts up, then starts to cycle on and off, it will stay on for 10-20 second then go off for a second and come right back on, it will do this for a while until it starts working normal again. It has a combo pilot/ignitor/sensor and it is brand new. Any ideas?
IFIXALL
  • 868 Answers
SOURCE: teledyne laars pool heater wont kick on
The safety valve isn't opening .It's very possible that a spider is trapping the opening of the orifice.
Posted on May 26, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: Laars boiler pilot light is blown out when burners shut off
Time for a cleaning and gas pressure test.
Posted on Dec 05, 2008
  • 246 Answers
SOURCE: Laars Teledyne lyte 250 will work intermittantly
have u clean t filter ? if continues check where are u loosing 24vac after the transformer there is the problem
Posted on Sep 13, 2009
  • 990 Answers
SOURCE: Ihave aTeledyne Laars mini therm jvt
You ether have an internal by-pass or an external one. If you have an external one you need to close it up to 80-90 persent. This will allow some water to go past the heater but most will go through it. If it is open too much the water will offer enough pressure to start the heater but if it doesn't flow through it. It will boil the water inside it and gurgeling and pounding as the water expands. If you have a problem with your internal by-pass you will get the same result but it is harder to fix. This is a disc mounted on a shaft held closed by a spring inside your water manifold on the heater. If you open the header you can get access to the by-pass and may be able to sand the shaft down or if the disc is broken you can replace it. Hope this helps and good luck.
Posted on Dec 20, 2009
SOURCE: have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Posted on Jan 05, 2010
How do I clean the heat exchangers in our Teledyne Laars boiler? Our unit is a JVT 100C
disconnect burn rack and remove turn off all power first then remove top and rinse out
Nov 12, 2017 | Pool & Spa
I am looking for a service agent for a Teledyne Laars Mark V pool hearter in Melbourne Australia
Hi there Bernhard Siefert... (G'day)
(from the other side of the date-line.. going out on the SF Bay today to watch our Blue Angels (again))... God Bless them...!
Easy to do...
(network search) Just search on your right combo...
I used
"Teledyne Laars spares service Melbourne Australia"
and got (after wading thru a lot of SF malarkey)
Spa Pool Gas Heater Repairs Service Conversions Maintenance
Try it yourself ... your results will probably be better...
http://www.ask.com/web?q=Teledyne+Laars+spares+service+Melbourne+Australia&qsrc=364&o=0&l=dir&qo=homepageSearchBox
There are lots of heater questions and answers on this site if you were thinking about getting your heater running quickly... but if you are un-comfortable with tubing wrenches and GAS heaters...
a qualified service technician usually SEEMS to be the safest approach.
I've always done my own repairs... because leaving explosives in the hands of rookies and apprentices scares me... and life is good.
Good luck... be safe!
Oct 09, 2016 | Teledyne Laars Pool & Spa
Just instaiied new mini-therm jvs75 starts up for 2 min water temp is 130 shuts down at 149
make sure plumbing is correct if so check the manual bypass that is on the header that the plumbing goes to may be it is stuck also make sure filters are clean
Feb 10, 2013 | Teledyne Laars HEAT EXCHANGER ASSEMBLY,...
My mini therm heater teledyne laars stay on all the time
either bad temp sensor or main board or stuck open gas valve need a professional to look at very dangerous
Oct 07, 2012 | Teledyne Laars Teledyne_ Laars Lite2...
Sep 13, 2009 | Teledyne Laars Pool & Spa
Heating & Cooling Logo
104 people viewed this question
Top Toastmaster Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you a Toastmaster Heating and Cooling Expert? Answer questions, earn points and help others
