Question about Dryers
Kemore 80 Series washer/wet clothes
you had helped me earlier and i wanted to know if you could tell me where to purchase this clutch and if it is easy to install.
  • 3,037 Answers
It should be relatively simple enough
1-800-366-PART (1-800-366-7278)
this should be kenmore's part number, they can get you what you need
Posted on Apr 24, 2008
I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Mar 17, 2010 | Kenmore 22422 Top Load Washer
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series model 110 after wash clothes are left soaking
when empty and off, open the lid and see if you can rotate the inner wash basket by hand. if you can easily, then the clutch is worn. This will prevent the basket from going into a high spin and wringing the clothes out. Replace the clutch by removing the top control panel, removing the clips that hold the cabinet, pull cabinet off, remove drain pump clips and pump, remove motor clips and motor, remove transmission (3 bolts). Now you will have access to the clutch, replace as needed, reverse dissasembly to complete. remember to unplug.
Jul 01, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 washer that spins but clothes are still too wet...
to me this sounds like a clutch,
or possibly worse, your transmission that is spitting oil onto your clutch
lift the front of the washer and check to see if there is a puddle of oil on the ground. if so, its most likely your transmission. and a clutch would be a temporary fix
but if no puddle, it is most likely just the clutch that needs replacing
May 26, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Series 80 washer model 23832100 spins slowly
It probably is your clutch. You will need to remove transmission to repair this.
May 12, 2009 | Kenmore 22422 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer top load
Sounds like the clutch/brake assembly is slipping.
Feb 17, 2009 | Kenmore 15864/15862 Top Load Washer
Kenmore series 90 washer spins but the clothes are still very wet
you probably need a new clutch (Whirlpool Washer Clutch Kit 285785 fits kenmore too) , or your gear case is shot.
Feb 13, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series
the clutch pads are worn or water/ oil has gotten on them.60a1aec.jpg the part is around $35.00 and it is about a 20 minute job for someone that knows what they are doing.4e82c7e.jpg
Jul 07, 2008 | Kenmore 24032\24036 Top Load Washer
Clothes still wet after spin cycle
the first 2 things you need to check is:
  1. if it is spinning as fast as it used to
  • if not it needs a new clutch assembly ($35 + labor)
  1. if it is draining as fast as it used to
  • if not then it needs a new water pump ($30 + labor)
there is no filter that would cause this problem. prices are from
  • if none of this describes the problem then let me know and i will help you figure it out. i know these machines well.
Jul 01, 2008 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
121 people viewed this question
Top Dryers Experts
