Question about Toshiba Satellite P100 Notebook
SCREEN HAS NO CONTRAST (BRIGHTNESS) AND IS HARD TO SEE VERY CLEARLY ANY SOLUTIONS
  • 415 Answers
Try using the fn key with the brightness key it should like a square with a sun/star in the centre and the same colour as the fn key font.
bon chance
Posted on Jul 28, 2010
How do I alter the colour, brightness, and contrast?
Go to menu, go to screen settings or display settings. Should bring up the sharpness, contrast, color, brightness controls. Follow directions on screen to adjust. Hope this helps!
Jan 29, 2016 | Televison & Video
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
Black screen (Philips 190G)
check the brightness / contrast control
do you see OSD (On Screen Display) Menu clearly?
Feb 08, 2010 | Philips 190B6CB/27 19" LCD
Monitor brightness contrast problem
Turn Off auto-adjustment screen
Jul 29, 2009 | Proview PL19Wb Monitor
Picture washed out, can't get it right
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Sep 21, 2008 | Akai LCT2715 27 in. LCD Television
Screen display
It's hard to find a Compaq manual their site, but they indicate you'll find this in the help files on your computer.
This is usually done with a combination of keys-look for the Fn key and a key that looks like a sun symbol. It may have an arrow pointing up or down. Use these keys together to change the brightness.
Oct 17, 2007 | HP (158800-001) for Compaq Presario 1246,...
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Open Questions:
Toshiba Satellite P100 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
